Текущее время: 30 апр 2024, 23:48
 Заголовок сообщения: replacement of rx80 gpu in rx 570 pcb
СообщениеДобавлено: 29 мар 2020, 03:42
Gentlemen, I installed a rx580 gpu on a rx570 pcb, both gigabyte, the pcb seems to be the same, however when trying to re-record the bios through amdvbflash I have the following error: incorrect subsystem id.
someone would know what to do to be able to re-record the biosa, because although the card is functional even for the game, gpu-z is unable to read the sensors.
 Заголовок сообщения: Re: replacement of rx80 gpu in rx 570 pcb
СообщениеДобавлено: 29 мар 2020, 03:45
if crystals are same, problem may be in pcb?
СообщениеДобавлено: 29 мар 2020, 04:40
To allow overriding subsystem Id just use non-gui version of atiflash.exe and pass "-fs" argument.
(but check to use 570 vbios for compatible PCB, preferably with the same number of power phases as your pcb)
СообщениеДобавлено: 07 апр 2020, 05:35
guys, follow the error I'm having when trying to update the bios, I used the unlockrom command, then I tried to re-record with -f and -fs, but this error still appears.
СообщениеДобавлено: 07 апр 2020, 14:20
You do NOT need unlockrom command.
But you need modern atiflash version that spports rx470/rx480 cards
https://www.techpowerup.com/download/ati-atiflash/
It DO contain cmd-line version too.
СообщениеДобавлено: 08 апр 2020, 01:18
galkinvv писал(а):
Mas você precisa da versão moderna do atiflash que suporta cartões rx470 / rx480 https://www.techpowerup.com/download/ati-atiflash/ Ele também contém a versão da linha cmd.
so ... I can't execute the commands in this 2.93 version of atiwinflash, do I have to download UEFI SHELL VERSON?
СообщениеДобавлено: 08 апр 2020, 01:53
No, UEFI SHELL VERSION is not needed.
Use amdvbflash.exe from 2.93 windows version.
Does 2.93 report any error?
Note: you should reboot windows to change atiflash version (different driver versions).
Or select "Show more versions" and use atiflash_277.zip
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook Pro 15 (820-2915-B) GPU replacement
в форуме Apple
bridx
29 авг 2017, 02:36
dupahuj Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Help missing component ASUS RX 570 Expedition | Помогите пропавшему компоненту ASUS RX 570 Expedition
katoda22
08 мар 2021, 21:46
katoda22 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Логические элементы RX 570 / HIS RX 570 не дает изображение
Legendary_Dovakin
18 мар 2022, 23:08
KlassTer Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI RX 570 ALL PORT DISPLAY SOUND WIERD | ВСЕ ПОРТЫ MSI RX 570 ЗВУК СТРАННЫЙ
katoda22
27 мар 2021, 22:05
В этой теме нет новых непрочитанных сообщений. error when increasing memory of rx 570 from 4gb to 8gb - ошибка при увеличении памяти rx 570 с 4гб до 8гб
TheMArcos
2681
12 ноя 2021, 12:51
agsmt Перейти к последнему сообщению
Сейчас этот форум просматривают: azzed, optpost, Stormrage, Yandex [BOT] и гости: 26
