Текущее время: 07 май 2024, 08:17
 Заголовок сообщения: Lenovo Yoga 500-14IBD ( LT41 Wistron 14217-1) Power Up Sequence question
СообщениеДобавлено: 14 апр 2020, 15:19
Lenovo Yoga 500-14IBD LT41 Wistron 14217-1
Hi,
this laptop have missing a voltage from power up sequence.
The 1D05V_M step is present only in in page 99 and 100 in schematic, but seems that there are no components connected to it.
It is the seven step in the power up sequence, and the PCH_RSMRST# is 2 step after it.
PCH_RSMRST# are reseting the PCH, (PCH_RSMRST# is 0,0v) so nothing functions after that.
Probably is a bug on the schematic.
The PCH_RSMRST# diode reading is .470 so no short-circuit in it.
There are some activity on bios, but a few pulses, on pin 1, and also on pin 5. (Pulses at pin 5 are below 2 volts)
This low voltage at pin 5 makes me think that problem is a pch/cpu related issue.
Can someone point me a in the right direction to solve the problem?
Thanks.
 Заголовок сообщения: Re: Lenovo Yoga 500-14IBD ( LT41 Wistron 14217-1) Power Up Sequence question
СообщениеДобавлено: 14 апр 2020, 17:04
Check PU4801 1D05V_PWR.
СообщениеДобавлено: 14 апр 2020, 18:46
No output from PU4801, activating signal, EC_PM_SLP_S3# is low level.
PM_SLP_S3# never present until PCH_RSMRST# is high.
СообщениеДобавлено: 14 апр 2020, 19:24
If I understood correctly, PM_RSMRST # is low.
Measure and show
3d3v_pwr
5v_s5
rsmrst#_kbc
3v_5v_pok
3v_5v_pok#
lid_close#
ac_in_kbc#
ecrst#
vd_in1, vd_in2
СообщениеДобавлено: 15 апр 2020, 18:43
Hi, these are the readings:
3d3v_pwr= 3.31v
5v_s5= 5.02v
rsmrst#_kbc= 0.0v
3v_5v_pok=3.2v
3v_5v_pok#= does not exist. ¿?
lid_close#=3.2v
ac_in_kbc#= 0.0v
ecrst#=3.2v
vd_in1, vd_in2= 3.2v, 3.2v
СообщениеДобавлено: 15 апр 2020, 19:12
andromedax писал(а):
rsmrst#_kbc= 0.0v
Check Q1701.
СообщениеДобавлено: 16 апр 2020, 15:10
IOD писал(а):
Check Q1701.
Q1701 replaced.
Q1701 pin 1, 3, 4, 5, 6-->0.0v
Q1701 pin 2-->3.2v.
Diode reading pin 3--> .470
СообщениеДобавлено: 16 апр 2020, 15:59
Check ADT_TYPE.
СообщениеДобавлено: 16 апр 2020, 19:59
IOD писал(а):
Check ADT_TYPE.
ADT_TYPE--> 0.44 volts with a 45w charger
ADT_TYPE--> 1.5 volts with lab psu and lenovo dc-jack adapter.
I will tray replacing kbc. (it is coming soon)
СообщениеДобавлено: 27 апр 2020, 11:09
Sadly kbc replaced but nthing changes.
PM_RSMRST# are always at low level.
Any advice?
В этой теме нет новых непрочитанных сообщений. lenovo yoga 500-14IBD (wistron lt41 14217-1m) очень сильно мерцает экран при работе от батареи
DeZQ
22 ноя 2020, 07:01
armagon Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo Yoga 500-14ibd (Wistron LT41 14217-1) нет реакций на кнопку
Дидар
14
1638
14 июл 2021, 08:06
Дидар Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. yoga 500-14ibd (LT41 Wistron 14217-1) Очистка МЕ
makar303
17 апр 2020, 15:12
makar303 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo yoga 500-14ibd ( LT41 MB 14217-1M) components missing
vortex252
11 сен 2017, 18:34
next6 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo Yoga 500-14IBD (LT41 mb 14217-1m) Тормозит при подключении БП
LSIS
13
483
22 фев 2024, 14:47
LSIS Перейти к последнему сообщению
Сейчас этот форум просматривают: ruv и гости: 29
