Текущее время: 27 май 2024, 21:11
 Заголовок сообщения: evga GTX 750Ti - help with mats analysis
СообщениеДобавлено: 08 май 2020, 01:48
hello, the symptom of the plate and the following, after loading the operating system the same as a colored screen, hour and white, hour is blue, I ran the mats and had the following result, 1 module pair felt an error, but I still haven't learned how to identify what is the module in question on the pcb. if someone can help me (and teach too, my english is kind of limited and google translate when translating from russian didn't help much)
This message will only appear once.
SUBPART RANK0 RD ERR RANK0 WR ERR UNKNOWN ERR
FBIOA[ 31: 0] 0 0 0
FBIOA[ 63: 32] 0 0 0
FBIOB[ 31: 0] 0 33 0
FBIOB[ 63: 32] 0 0 0
Rank 0 Failing bits:
B000 B001 B002 B003 B004 B005 B006 B007 B008 B009 B010 B011 B012 B013 B014 B015
Read Error Count: 0
Write Error Count: 33
Unknown Error Count: 0
BIT RANK0 WRITE RANK0 READ UNKNOWN
B000 2 0 0
B000 4 0 0
B000 4 0 0
B000 6 0 0
B001 5 0 0
B001 5 0 0
B001 1 0 0
B001 7 0 0
B002 4 0 0
B002 1 0 0
B002 6 0 0
B002 2 0 0
B003 5 0 0
B003 2 0 0
B003 3 0 0
B003 3 0 0
B004 4 0 0
B004 4 0 0
B004 4 0 0
B004 5 0 0
B005 8 0 0
B005 8 0 0
B005 7 0 0
B005 7 0 0
B006 4 0 0
B006 3 0 0
B006 5 0 0
B006 6 0 0
B007 3 0 0
B007 2 0 0
B007 2 0 0
B007 2 0 0
B008 6 0 0
B008 6 0 0
B008 6 0 0
B008 6 0 0
B009 6 0 0
B009 6 0 0
B009 6 0 0
B009 6 0 0
B010 6 0 0
B010 6 0 0
B010 6 0 0
B010 6 0 0
B011 3 0 0
B011 2 0 0
B011 2 0 0
B011 2 0 0
B012 3 0 0
B012 2 0 0
B012 2 0 0
B012 2 0 0
B013 3 0 0
B013 2 0 0
B013 2 0 0
B013 2 0 0
B014 3 0 0
B014 2 0 0
B014 2 0 0
B014 2 0 0
B015 3 0 0
B015 2 0 0
B015 2 0 0
B015 2 0 0
ADDRESS EXPECTED ACTUAL REREAD1 REREAD2 FAILBITS TPSEIB ROW COL
0000002638 00000000 00000763 00000763 00000763 00000763 WB0086 0000 0ce
0000002630 00000000 00000775 00000775 00000775 00000775 WB0084 0000 0cc
0000002628 00000000 00000773 00000773 00000773 00000773 WB0082 0000 0ca
0000002620 00000000 00000720 00000720 00000720 00000720 WB0080 0000 0c8
0000002618 00000000 0000076f 0000076f 0000076f 0000076f WB0086 0000 0c6
0000002610 00000000 0000074e 0000074e 0000074e 0000074e WB0084 0000 0c4
0000002608 00000000 00000720 00000720 00000720 00000720 WB0082 0000 0c2
0000002600 00000000 0000073a 0000073a 0000073a 0000073a WB0080 0000 0c0
0000002678 00000000 00000773 00000773 00000773 00000773 WB0086 0000 0de
0000002670 00000000 00000765 00000765 00000765 00000765 WB0084 0000 0dc
0000002668 00000000 00000763 00000763 00000763 00000763 WB0082 0000 0da
0000002660 00000000 0000076f 0000076f 0000076f 0000076f WB0080 0000 0d8
0000002658 00000000 00000772 00000772 00000772 00000772 WB0086 0000 0d6
0000002650 00000000 00000770 00000770 00000770 00000770 WB0084 0000 0d4
0000002648 00000000 00000720 00000720 00000720 00000720 WB0082 0000 0d2
0000002640 00000000 00000768 00000768 00000768 00000768 WB0080 0000 0d0
00000025b8 00000000 00000753 00000753 00000753 00000753 WB0086 0000 02e
00000025b0 00000000 00000720 00000720 00000720 00000720 WB0084 0000 02c
00000025a8 00000000 0000073a 0000073a 0000073a 0000073a WB0082 0000 02a
00000025a0 00000000 00000765 00000765 00000765 00000765 WB0080 0000 028
0000002598 00000000 00000774 00000774 00000774 00000774 WB0086 0000 026
0000002590 00000000 00000775 00000775 00000775 00000775 WB0084 0000 024
0000002588 00000000 0000076f 0000076f 0000076f 0000076f WB0082 0000 022
0000002580 00000000 00000772 00000772 00000772 00000772 WB0080 0000 020
0000002680 ffffffff ffff0773 ffff0773 ffff0773 0000f88c WB0080 0000 0e0
00000025c0 ffffffff ffff0749 ffff0749 ffff0749 0000f8b6 WB0080 0000 030
00000025c8 ffffffff ffff074f ffff074f ffff074f 0000f8b0 WB0082 0000 032
00000025d0 ffffffff ffff0743 ffff0743 ffff0743 0000f8bc WB0084 0000 034
00000025d8 ffffffff ffff0744 ffff0744 ffff0744 0000f8bb WB0086 0000 036
00000025e0 ffffffff ffff0745 ffff0745 ffff0745 0000f8ba WB0080 0000 038
00000025e8 ffffffff ffff074c ffff074c ffff074c 0000f8b3 WB0082 0000 03a
00000025f0 ffffffff ffff0752 ffff0752 ffff0752 0000f8ad WB0084 0000 03c
00000025f8 ffffffff ffff0754 ffff0754 ffff0754 0000f8ab WB0086 0000 03e
if you are getting failure for first MBof FB then try option -no_scan_out
Error Code = 00000001
this is pcb to card
 Заголовок сообщения: Re: evga GTX 750Ti - help with mats analysis
СообщениеДобавлено: 08 май 2020, 02:03
СообщениеДобавлено: 08 май 2020, 02:15
thanks!!!
31:00 would be the low
and 63:32 would be the high?
СообщениеДобавлено: 08 май 2020, 02:34
yes
СообщениеДобавлено: 08 май 2020, 02:37
so I think I understand how mats reading works, thanks again.
I will bring the result
Posted after 3 hours 7 minutes 59 seconds:
hello again, I have a doubt ... the memories of this card are elpida W4032BABG-5-F
is it possible to replace with samsung K4G4132FC HC03? if possible, do I need to replace the pair? or just one
Posted after 1 hour 59 minutes 7 seconds:
I managed to find an identical module, replace it and guess what? msm remains 33 writing errors ...
next step? reball?
СообщениеДобавлено: 08 май 2020, 15:50
I left the card for 7 hours at full mark and she no longer presented the single color screen, but I noticed that she is only giving video through the dvi output, with no video signal via hdmi.
suggestions?
СообщениеДобавлено: 11 май 2020, 07:20
hello, after reball to gpu the card 100% functional!
thanks everyone.
В этой теме нет новых непрочитанных сообщений. GTX 1070 Strix, weird artefacts on screen (mats ok) - странные артефакты на экране (mats ok)
cxav
21 фев 2021, 12:42
В этой теме нет новых непрочитанных сообщений. GTX 1070 EVGA, артефакты памяти, MATS
[ На страницу: 1, 2, 3 ]
dikabraz
82
12223
14 мар 2020, 10:26
fffas Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. help for asus x552e (help for asus x552e) help
serwanjaf7
05 авг 2016, 18:08
serwanjaf7 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Help help Help memory samsung detect micron (domate)
PT-AH
02 ноя 2022, 14:43
PT-AH Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus gtx 750ti 2gb (c2010g)
BlackFoxInBox
11 янв 2019, 12:03
BlackFoxInBox Перейти к последнему сообщению
Сейчас этот форум просматривают: bd250, Leon1898 и гости: 17
