Текущее время: 03 июн 2024, 16:08
 Заголовок сообщения: RTX 2080 Fan shorted
СообщениеДобавлено: 10 май 2020, 21:12
Hi,
I have an RTX 2080 in reference design on the table. According to the owner, the card had a short in the fan area.The owner tried something on the card during operation. According to the postcard, the card gets stuck at 2A. I found and replaced two dead 0 ohm resistors next to D3. There is no short on the 0hm resistors. Error still remains. Does anyone have a boardview or schematics for the card? I would also take a screenshot of fan control. Of course I would also pay for it.
Kind regards
Posted after 3 minutes 45 seconds:
The power supplies are all ok and supply all voltages.
 Заголовок сообщения: Re: RTX 2080 Fan shorted
СообщениеДобавлено: 10 май 2020, 21:53
who is the manufacturer of the video card?
take a photo of the section with resistors.
СообщениеДобавлено: 11 май 2020, 23:43
It is a Palit card, I can take pictures tomorrow.
greetings
СообщениеДобавлено: 12 май 2020, 18:13
Unfortunately I don't know the pinout from the connector.
That's why I once measured the 4-pin fan connectors that are plated through to the 14-pin connector.
I have replaced the two 0Ohm resistors but this was not successful. The old ones were broken.
СообщениеДобавлено: 12 май 2020, 22:08
srigg
What do you want to know from fan control? i have now on table palit rtx 2070 it looks very similar..
Posted after 2 minutes 46 seconds:
srigg
on your cards pin where you measured 4ohm should be kohms there is your short..
СообщениеДобавлено: 12 май 2020, 22:47
I am looking for the circuit. on a 1080 the "FAN TACH" pin goes from the fan to the GPU and to a diode direction 3.3v. Is it the same with the 2080?
kind regards
СообщениеДобавлено: 13 май 2020, 11:56
may be that help you
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Idenitfy component on shorted rail ASUS ROG Strix 2080
MSIGamer72
07 мар 2021, 15:31
MSIGamer72 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus RTX 2080 Ti Turbo - 100% fan and no signal.
Micchaleq
07 май 2021, 23:49
Micchaleq Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Converter Rtx 2070s im Rtx 2080
TheMArcos
15 ноя 2020, 23:09
nemos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Predator Triton 500 Predator (Wistron Ghibli 18803-SC) Change GPU rtx 2060 to rtx 2080?
pcexpert8
25 сен 2022, 23:08
pcexpert8 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. hp 8440 (fan not spin ) fan not spin in battery mode
rajeshkumar
26 авг 2016, 12:32
rajeshkumar Перейти к последнему сообщению
Сейчас этот форум просматривают: pcm-nn, sasha_m, Тимур Кан и гости: 17
