Текущее время: 19 май 2024, 23:15
 Заголовок сообщения: Hp dv7-2205EL turns on and turns off immediately
СообщениеДобавлено: 30 сен 2012, 13:53
As the title suggests the handset will turn on for 2 seconds and then turns off.
The motherboard is: 509404-001, and DAUT1AMB6D0 Rev D.
I have the following diagram,
DV7_-_QUANTA_UT12_DISCRETE_-_REV_1A
I do not know if it fits.
Thanks
 Заголовок сообщения: Re: Hp dv7-2205EL turns on and turns off immediately
СообщениеДобавлено: 30 сен 2012, 14:05
Check PQ41.
СообщениеДобавлено: 30 сен 2012, 15:14
PQ41 ---> 0V on all pins
СообщениеДобавлено: 30 сен 2012, 15:44
Необходимые условия для старта платы выполняются?
What resistance on Drain, Source, Gate to GND?
СообщениеДобавлено: 30 сен 2012, 17:01
Which part should I check? How do I start to find the fault
thank you
СообщениеДобавлено: 30 сен 2012, 17:23
Ciber SLasH wrote
0. When the main BIOS and EC-bios 100% working.
1. When a voltage is cartoon that it is working and quartz cartoon bios proofread (see communication on flash BIOS oscilloscope).
2. When ACIN = 3.3V
3. When LID_SW # = 3.3V
4. When cartoon remove reset from the south, that is, EC_RSMRST # = 3.3V
5. When you press the alarm signal ON / OFFBTN # drops to zero and the same signal is broadcast in PBTN_OUT #
6. When the signals from the south and PM_SLP_S3 # SLP_S5 # are reset, ie voltage on them will be 3.3V.
Under these conditions the cartoon is to give the command to start.
СообщениеДобавлено: 01 окт 2012, 08:40
Check - i.e. replace this part.
booknot.ru тел (343)237-37-37
СообщениеДобавлено: 01 окт 2012, 13:06
I replace the PQ41, now flash the power jack
СообщениеДобавлено: 01 окт 2012, 13:18
Before replacing pq41 the power jack not flash?
Check pq41 soldering and what replaced it the same or analogue?
СообщениеДобавлено: 01 окт 2012, 14:43
replaced it the analogue
СообщениеДобавлено: 01 окт 2012, 14:57
what transistor do you install? check the 1-st pin and MOS type
СообщениеДобавлено: 01 окт 2012, 18:22
replaced with AO4430
СообщениеДобавлено: 01 окт 2012, 18:26
You need install the transistor with Rds less than 0.0135 OHm @ VGS = 10 V
СообщениеДобавлено: 01 окт 2012, 19:34
Hello,
I have a motherboard parts for parts, not working Hp pavilion dv6500 with the code: DA0AT3MB8F0 REV: F.
Please help me find a part to replace the Pq41.
thank you very much
СообщениеДобавлено: 02 окт 2012, 07:46
Usually I take transistor from CPU core power circits.
В этой теме нет новых непрочитанных сообщений. ASUS M2N-MX SE Plus immediately hangs in the windows and not off !!!
в форуме Asus
jonathanieq
10 сен 2015, 22:48
jonathanieq Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. VPCEH (MBX-247 HK1) turn off immediately in gpu stress test
в форуме Sony
R EZ A
09 фев 2017, 01:12
R EZ A Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo B590 (Wistron LB59A) turns on and off constantly
antony
22 ноя 2014, 02:06
antony Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. notebook dell vostro 3500 (Dell Vostro 3500 056tk2 10865) heats up and turns off after a few seconds
в форуме Dell
eletmoraes
28 апр 2018, 02:11
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Msi R7 370 2g armor turns on and off 2 seconds later
TheMArcos
1544
10 май 2020, 20:16
TheMArcos Перейти к последнему сообщению
Сейчас этот форум просматривают: Google [Bot], i001546 и гости: 25
