Текущее время: 08 май 2024, 02:38
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 11 июн 2020, 19:22 |
Зарегистрирован: 27 фев 2020, 13:07 Наличности на руках: 313.76
Сообщения: 295 Откуда: romania
RsM писал(а): what's a problem? It it possible to solve it without schematic if you have a brain.
Hello i have short after the 400v rectifier. It is hard to remove components like hell to see what is causing it
Witewut
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 12 июн 2020, 09:37 |
Зарегистрирован: 14 дек 2016, 02:24 Наличности на руках: -15.00
Сообщения: 619 Откуда: Рига
resistors, capacitors, npn pnp transistors, PMW APFC controller, electrilitic capacitors around controller, Stand by power supply. Check big capacitor find datasheet of PMW APFC controller, check Vcc, may be other pins too acording datasheet. Seems You have LLC resonant half-bridge topology, try to find in google pdf "LCC ATX PSU", seems onsemi had pdf with circuit. https://www.onsemi.com/pub/Collateral/TND359-D.PDF
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 12 июн 2020, 23:30 |
Hello until now i found this: One diode and 2 mosfet dead all pins in short. See photo Вложение: 20200612_222726.jpg The schematic is approximate So i should check their driver no?
RsM
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 13 июн 2020, 15:48 |
Модератор |
Сообщения: 8264 Откуда: Сыктывкар
ICE3PCS01GICE2HS01Gilie321 писал(а): I didn't found other components with problems. What i can do? Bridge is ok? Is the short on the outpun terminals? 12/5/3.3/-12 Drivers to these Power Moset's is ok or not? Standby PSU is ok or not? ( need to replace diod first and mosfets you've found before)
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 13 июн 2020, 18:25 |
RsM писал(а): Bridge is ok? Is the short on the outpun terminals? 12/5/3.3/-12
Drivers to these Power Moset's is ok or not? Bridge ok No short on any output voltage from atx24 How to check driver? No short on gate (on pcb) of those 2 faulty mosfet after removing them from pcb. I don't have this types of mosfet. I will search for similar but i do not know if it is a good idea to replace them with other types.
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 18 июн 2020, 08:51 |
in few days i will get those 2 dead mosfets and diode (dead=all 3 pins in short) any advice what to check before power up the psu? 1 standby voltage after cable connection and no booooom ? 2? driver for this mosfets is strange controller board has main chip and some 8pin operational amplifier on it and from this boards is going by a transformer to mosfet gates Something like this: Вложение: 20200618_094936.jpg I checked all small value resistors no fault found I checked all diodea and transistors no fault found No capacitor în short on controller board Also in primary side of psu i checked all diodes and resistors and transistors
RsM
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 18 июн 2020, 12:10 |
Модератор |
ilie321first of all, your mistake is that you want help, but you do not share information about what IC's are, smd transistor are, no photo. look at my postsMore info - more help, no info - no help, it's very simle. ilie321 писал(а): standby voltage after cable connection use a 60-100W light bulb in series (instead of FUSE) to check standby PSU voltage. If it's Ok, than use a 500-800W light bulb or an iron 1000-2000W or a hair dryer 1000-2000W insted and try to power on main PSU. Do not load PSU more then 100W with light/iron/hd!/
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 18 июн 2020, 13:23 |
quote="RsM"]ilie321 first of all, your mistake is that you want help, but you do not share information about what IC's are, smd transistor are, no photo.[/quote] More photos: Вложение: 20200618_115708.jpg Вложение: 20200618_120708.jpg Вложение: 20200618_121947.jpg
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 23 июн 2020, 18:32 |
Ok I put a 100w bulb instead of a fuse for testing. I replaced the bad mosfets ipa50r140 and diode. I have the 5v standby now. Any test I can do before I try to enable it? Or any info I could give you guys to help me? Or I can pass to this? : Цитата: than use a 500-800W light bulb or an iron 1000-2000W or a hair dryer 1000-2000W insted and try to power on main PSU.Do not load PSU more then 100W with light/iron/hd!/ . I have an 1000w air heater I will use that I think It is enough to ground pwr_on for this power supply? Dumb question :) Thank you
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 24 июн 2020, 10:08 |
RsM писал(а): Try with 1000w air heater Not working. No voltage on outputs it stay 0 and it is making a strange intermitent coil noise 2-3 times per second. The air heater it is starting. I setup air heater for 750w. I have 1500w step on it also. See here the noise: https://drive.google.com/file/d/1-1VmVg ... p=drivesdkNothing blow. mosfets are OK thanks to air heater :). Should I change the controller? (2months maybe to wait for aliexpress) I could check the pulses with oscilloscope on mosfets gates maybe. Posted after 2 hours 38 minutes 34 seconds:I have a B6 smd Q35 in secondary side that should be a transistor after Q marking (see picture) . On internet is a pnp but many devices same code. If I measure it as pnp is nok. Maybe a false direction but I don't know what to do. Вложение: 20200624_114150.jpg
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 25 июн 2020, 18:28 |
RsM писал(а): then the voltage will be 360-390V 360-390 with that 750w air heater? It adds 70ohms in ac I measured in standby 330v (with air heater as fuse) With Ps_on at ground 330-360V but it varies much maybe because the source try to start every 0.3seconds I edited last post both mosfets get impulses. 3.3V 13kohms+ 5v 8k+ 12v 7k+ -12v 9k+
RsM
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 25 июн 2020, 20:01 |
Модератор |
ilie321 писал(а): I have 1500w step on it also. try with this mode and now check input voltage.
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 26 июн 2020, 15:36 |
And dead end both mosfets died again and I never keep them up more than 3 - 4 seconds on 750w air heater Now I will wait 2 months the new ones from Ali and new controller. In my country x10 price comparing with Ali. Sad so hard to diagnose switching psu. RsM писал(а): try with this mode and now check input voltag What you think until now?any chance
