Текущее время: 11 май 2024, 21:29
Assassin
Заголовок сообщения: RTX2080TI strange issue - all VRMs works fine but GPU still in reset state Добавлено: 12 июл 2020, 01:54 |
Зарегистрирован: 14 май 2020, 20:12 Наличности на руках: 78.21
Сообщения: 61 Откуда: germany
Hello there. i have a Palit Dual RTX2080TI here with strange issue...card wont dedect, also not in Windows with secondary graphic card, and on USB RiserCard it draw only round 1,5A@12V. All VRMs works fine, no mosfet report a fault, 5V and 1.8V present, up9512P PGood is high - but gpu still seems to be in reset state. I think gpu isnt become the vrm ready signal, but how/where can i check this? GPU is only slowly warms up, but not too much.
its a reference design pcb. any tips for me?
Assassin
Заголовок сообщения: Re: RTX2080TI strange issue - all VRMs works fine but GPU still in reset state Добавлено: 13 июл 2020, 23:35 |
this one choke with 0V is - i think - normal. I think it's the load balancing system i heard from several teardown videos...or not? about the lower 3 memory modules - i have desoldered it because one of them was already swapped, and so i was able to check the solder pads and the memory itself in diode mode - all 3 modules are ok. Card was also not started without this 3 memorys. draws only round 1,6A@12V without heatsink
madking
Заголовок сообщения: Re: RTX2080TI strange issue - all VRMs works fine but GPU still in reset state Добавлено: 13 июл 2020, 23:51 |
Зарегистрирован: 03 ноя 2017, 01:24 Наличности на руках: 5,012.04
Сообщения: 3986 Откуда: Budapest
wash the crystal is not clear crack or thermal grease Вложение: dscf1753wlkwf.jpg Assassin писал(а): this one choke with 0V is - i think - normal. - normal - USB-C
