Текущее время: 02 май 2024, 05:18
 Заголовок сообщения: Msi Z87 XPower no usb and ps2 in the bios (cant do anything in the bios)
СообщениеДобавлено: 12 июл 2020, 14:01
Hi guys. My problem is that i cant use a keyboard and mouse in the bios at any usb and ps2 port. First time i see something like that. All ports working fine in windows. They are working also fine just before you go in to the bios (you can click "del" to go in to the bios no problem). Bios is not freeze (you can see changing cpu temp.). Only thing you can do in bios is press ctrl+alt+del and then it will restart but you cant do anything else. I tried both new bios versions from Msi website 1.7 and 1.8 nothing changed. Tried ps2 keyboard no changed. I removed ESD protecion component from one of the port - nothing changed. Question is - is it some kind of wierd HUB malfunction or some of You had any ideas where to dig? Thank you for any help in advance.
 Заголовок сообщения: Re: Msi Z87 XPower no usb and ps2 in the bios (cant do anything in the bios)
СообщениеДобавлено: 13 июл 2020, 08:53
FASTB1: GO2BIOS Button
If you enable the "MSI Fast Boot" feature in BIOS, the keyboard will be unavaiable and
entering BIOS Setup by pressing DEL will not function. Once you press this button,
the system will enter BIOS setup directly at next boot.
https://www.msi.com/Motherboard/support ... own-manual
СообщениеДобавлено: 14 июл 2020, 13:07
There is no problem go in to the bios, i can do it every time. Problem is that i can not do anything inside the bios (there is no mouse cursor and keyboard doesnt respond). Only what i can do inside a bios is press "ctrl+alt+del" and then it will restart, nothing else works. It looks like is locked from editing somehow but how???? Becouse of that i cant modyfi anything in the bios.
СообщениеДобавлено: 14 июл 2020, 15:16
https://forum-en.msi.com/index.php?topic=169796.0
https://www.overclock.net/forum/6-intel ... -bios.html
https://forums.guru3d.com/threads/keybo ... os.386196/
https://forum.overclockers.ua/viewtopic ... 3&start=80
В этой теме нет новых непрочитанных сообщений. Asus Z87-K и Z87-A , не работают USB
в форуме Asus
Sosisko
11
1943
15 янв 2023, 10:10
vit975 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Mods không nhận card ai có thể giúp tôi?
thanhnamvl86
13 ноя 2019, 13:09
virus-cyber Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Pavilion 11-h000ew (DA0W03MBAH0 rev H ) i cant find BIOS file DUMP
midar
09 ноя 2016, 17:54
В этой теме нет новых непрочитанных сообщений. MSI MS-7A21 Ver:1.0 X99A XPOWER GAMING TITANIUM
в форуме MSI
Bir Volt
05 апр 2019, 02:45
Bir Volt Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI Z170A XPOWER GAMING TITANIUM EDITION (MS-7968 VER3.1) СБИТЫ ЭЛЕМЕНТЫ
в форуме MSI
Сергей988
26 июн 2022, 08:02
Vl-soft Перейти к последнему сообщению
