Текущее время: 03 июн 2024, 14:37
 Заголовок сообщения: Palit Dual GTX 1060 6GB GPU died ??
СообщениеДобавлено: 16 июл 2020, 00:32
There are all voltages on the card. Resistance of the 60 ohm pci controller, 1.6 ohm gpu, samsung 25 ohm memory. The card starts very long, then displays Black image with weird colored dots. GPU died or memory ??
 Заголовок сообщения: Re: Palit Dual GTX 1060 6GB GPU died ??
СообщениеДобавлено: 16 июл 2020, 07:18
If starts - try to test with MATS.
СообщениеДобавлено: 16 июл 2020, 17:21
The card was tested in Mat Mods. The last of the banks in the C channel is damaged, after the replacement is still a black screen with dots. I removed the memory chip again. Guided by this : https://www.youtube.com/watch?v=syJIAWYfUAY&t=339s , I measured all points running to the core. At one point, the mulitimer showed 0.L looks like empty pad. What to do next?
СообщениеДобавлено: 16 июл 2020, 17:29
GPU reball
---------- Добавлено спустя 7 минут 15 секунд: ----------
check contact gpu-vram
СообщениеДобавлено: 16 июл 2020, 18:48
What is the memory channel you removed?
Does the BIOS of your card complains (via CRC32) to any of this card placed on the techpowerup's base?
СообщениеДобавлено: 17 июл 2020, 14:57
In device manager car have error 43.I remove last bank on chanel C FBIOC [31: 0] .I measured resistance again ,most pads have 5K OHM , two or three have 3,1 -3,8 K OHM .Are such differences in resistance acceptable?
СообщениеДобавлено: 17 июл 2020, 15:26
Use "diode voltage drop" mode on multimeter instead of "resistance mode". It has less random deviations.
СообщениеДобавлено: 19 июл 2020, 23:10
After reflow gpu ,there was resistance on this empty pad 5K OHM. I soldered banks and the card gave the picture.Thanks for help. :co_ol:
В этой теме нет новых непрочитанных сообщений. Zotac GTX 1060 6gb cannot install driver | Zotac GTX 1060 6gb не может установить драйвер
katoda22
28 мар 2022, 21:03
GerIlja Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Zotac GTX 1080 8GB artifacts died memory or gpu ??
allas
12 дек 2020, 16:27
allas Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Palit GeForce GTX 1060 Dual 6GB на стеройдах, черный экран. Gp106-400-A1 Gp104-200-A1
Сц Гост
6018
14 апр 2024, 14:09
Error_2022 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 1060 6gb palit dual, зависает на b2
[ На страницу: 1, 2 ]
dikabraz
34
5580
10 апр 2022, 15:12
usyny Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. palit gtx 1060 Dual 6gb (ne51060015j9-1061d) артефакты и зависание
reddog
31 окт 2021, 15:32
reddog Перейти к последнему сообщению
Сейчас этот форум просматривают: leonemax81, rulya56, TomaszR, zettabyte и гости: 14
