hi guys i have problem with asus n551jk it not power on with charger but it ok with battery so i have same problem before and with change ic charge and all mosfet it ok but in this case no answer is there any one can help me??? please Posted after 8 minutes 1 second: if i jump PQ8801 mosfet it will power on but cant charging... without jumping mosfet it not power on with charger
Krydsvard
Заголовок сообщения: Re: asus (n551jk) charging
Добавлено: 04 авг 2020, 21:56
Зарегистрирован: 10 май 2019, 21:56 Наличности на руках: 11.53 Сообщения: 142
The problem pq8801 won`t open? What ic charger voltages acdrv-4, acdet-6, regn-16, vcc-20 pins?
