Текущее время: 01 июн 2024, 15:12
 Заголовок сообщения: Palit GTX1070 Super Jetstream / Founders PCB vMEM issue
СообщениеДобавлено: 23 авг 2020, 23:29
Hello there, i have here a GTX1070 with an error in memory power supply.
i have already testet the whole card - direct connect a external Powersupply that deliver 1,5V with 20A - and card works fine with it.
i have already swap the R33 coil, the dual N Mosfet and the PWM Controller also - withaut any change in error.
Controller is a default Founders memory controller, a 7J=3D (7J=xx) - with is a renamed RT8816A controller.
i have already checked near all things around the controller. No shorts in any capacitor, no shorts in Mosfet gates.
Measurements are:
PVCCC: 5V
EN: 1.8V
RTon: 550 kΩ against VIN (12V)
PSI: 0.8V
VREF: 2.0V
VRefIN: 1.52V
OCSET: 77kΩ
VID: 1.8V (no PWM)
Bootstrap C: 97nF
RGND: 0.2Ω against ground
VSNS: 33Ω against Ground or 0,2Ω against VOut (memory voltage after R33 coil)
i have also dissconect the OCSET/SS pin from external SoftStart resitor/capacitor, and it will only rise to 163mV, but in datasheet it should be rise to over 2V. so i think the controller is in error state directly after start.
Both gates from dual N mosfet is forcfully held low
so what can be happened here?
*edit* sorry with my old thread, i accidentally closed it :smu:sche_nie:
 Заголовок сообщения: Re: Palit GTX1070 Super Jetstream / Founders PCB vMEM issue
СообщениеДобавлено: 24 авг 2020, 03:36
already tried to change the controller?
СообщениеДобавлено: 29 авг 2020, 00:47
already changed :-/
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GTX1070 Founders - no Memory Voltage, with external Memory-Power all fine
Assassin
23 авг 2020, 23:26
Assassin Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Samsung keyboard maping issue NP450R5E (ramos) keyboard maping issue
в форуме Samsung
minanpil13
03 апр 2019, 10:30
minanpil13 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. NVIDIA GeForce RTX 2060 Super Founders Edition
Walkman
23 май 2024, 07:12
Walkman Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Palit GTX1070 Jetstream
youngwar
21 ноя 2019, 18:54
В этой теме нет новых непрочитанных сообщений. Palit Jetstream GTX1070 пропадает питание
elgordo
25 мар 2021, 06:21
elgordo Перейти к последнему сообщению
Сейчас этот форум просматривают: Cifragrad, Lexa-Yalta, sashok289 и гости: 18
