Текущее время: 16 май 2024, 06:19
 Заголовок сообщения: Asus rog (g752jy) Power led not working
СообщениеДобавлено: 06 сен 2020, 11:18
So, this laptop was broken..i tested it..find short...replaced ITE chip and 3/5 voltage regulator and everything is working fine...i tested it and all ok...but...later when i tried to put it together every time i connected touchpad button the red light on the power button was missing (the laptop is working, touchpad is working) just missing that red power button light). And when i unplug touchpad it was there... So whats going on...?
I measure power led on both side and it is 5,06 V on one side...but when touchpad is connected there is a difference on other side "PWR_LED_CON#_1" ...when touchpad is not connected it is 3,26 V but when connected it is 3,7 V. Ok, so that it is why i dont see red power button light...
So i inspected touchpad ribbon cable and connector and everything seems fine...i even used a second touchpad button of the same model i have and same...no red light when connected. Oh and i should mention that touchpad button is working fine when connected...only no led light on main power button.
So i use schematic (attached similar model but should be the same) and i found following:
1. PWR_LED_CON#_1 without touchpad 3,2, with touchpad button 3,7
2. PWR_LED_CON# is on pin 9 of touchpad...should be 0 v but it is 2,8 V. Also it is shorted with 0 ohm resistor to a "PWR_LED_R#" (gate on mosfet )
3. Without touchpad connected the readings on n mosfet are pin 2,3 0 v, pin 1,4 GND, pin 5,6 are 3,3 V (i believe this is ok, as it shoud be always)
4. When touchpad connected readings are on pin 5,6 are 0v, and on pin 2 it is 2,8v, pin 3 it is 3,7 v
So far i tried check for short (didnt find),replaced mosfet but the same; then i removed 0 ohm resistor R5620 and now i have a light on main power button...but problem is still present on the other side signal PWR_LED_CON# which is generated from touchpad button ? according to the scheme...but i dont understand how?
I measure every pin from touchpad button on working and this laptop and only difference is in pin 9 PWR_LED_CON# ...on working laptop is 0 v but on this it is 2,7 V. I am not able to figure how PWR_LED_R# is generated?
 ! Ciber SLasH писал(а):
Forum rules violation !!
II.10. To download the schemes and any other files which are already in the forum is forbidden.
II.12. To attach schemes to the messages is forbidden. For this purpose there is the appropriate theme in each subsection of the specific producer.
 Заголовок сообщения: Re: Asus rog (g752jy) Power led not working
СообщениеДобавлено: 07 сен 2020, 07:00
or bad soldering, or broken tracks
СообщениеДобавлено: 07 сен 2020, 13:00
Do you mean bad soldering on touchpad connector?
Tracks are i believe are ok because i checked for continuity.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer Q5WV1 rev.2.0 (LA-7912P) does not light any LED panel, not power
eletmoraes
21 апр 2016, 11:32
andromedax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Hp g62-b19sl (Turns on LED power alone) Turns on LED power alone
amennone
09 фев 2018, 01:38
desertearch Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. dell P41G002 (DAJW8CM8E1 REV: E) no power , led battery on , led power off
в форуме Dell
eletmoraes
24 фев 2020, 23:01
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus G751J (G752JY Rev:2.0) Нет инициализация.
Abbas Abbasov
09 июн 2019, 16:00
sonidista Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Hp (4520s) Not power on ... dc jack led flashing
nasser_pczone1
18 июл 2018, 12:38
nasser_pczone1 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 29
