Текущее время: 28 апр 2024, 17:35
 Заголовок сообщения: RTX 2080Ti - possible to use unused memory Pad?
СообщениеДобавлено: 13 сен 2020, 01:33
hello there, is it possible to use the one unused memory solder pad on a RTX2080TI when another memory bank is physical damaged? (tracers ripped off)?
on Founders/reference PCB, its always the Pad chanel A0 which is unused.
i have seen a RTX2080ti where it was C0 which have no memory, but for that on A0 was also an memory chip soldered.
like this one:
So - how does the card address the right memory channel/bank? also with resistors similar with the one on the back for Micron/samsung memory?
 Заголовок сообщения: Re: RTX 2080Ti - possible to use unused memory Pad?
СообщениеДобавлено: 13 сен 2020, 11:31
No. In this case, it is impossible to use channel A0. It is disabled in the GPU itself. Where you find C0 - look at the GPU markings and compare with where there is no A0.
For example, if the marking ... KA-A1 then the memory bank A0 is disconnected. If the marking ... KС-A1 the channel C0 is disconnected accordingly.
СообщениеДобавлено: 13 сен 2020, 19:38
ok, thanks.
there a only TU102-300(A)-K1-A1 and TU102-300(A)-K5-A1 known. Only these 2 GPUs (as 300A and only 300 without A) was seen on RTX 2080TI
СообщениеДобавлено: 14 сен 2020, 20:06
another question:
where is the resistor strap on RTX2080TI where i can switch from micron to samsung memory when i will replace all chips?
i know only pictures from RTX2070 and 2080 - but not for the TI.
В этой теме нет новых непрочитанных сообщений. use mats in card that the video, it is possible?
TheMArcos
28 авг 2020, 23:46
Conqueror Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 2080TI, 3 memory chips broken?
Assassin
2659
27 май 2020, 08:04
Assassin Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 2080 tracing disconnected pad under memory
Mosasha
966
14 мар 2021, 14:30
В этой теме нет новых непрочитанных сообщений. toshiba A70-S256 (LA2301 rev 1) What kind of memory to use the A70-S256 toshiba?
в форуме Toshiba
eletmoraes
29 мар 2016, 22:07
В этой теме нет новых непрочитанных сообщений. I need to find dump of the motherboard Asus M2N-MX SE plus rev: 2.02G and what memory to use.
в форуме Asus
eletmoraes
09 окт 2017, 08:13
AronEl Перейти к последнему сообщению
Сейчас этот форум просматривают: Mr. Elias и гости: 43
