Заголовок сообщения: G502VM (GL502VM rev 2.0) It is possible to disable gtx1060
Добавлено: 17 сен 2020, 14:36
Зарегистрирован: 05 май 2012, 14:33 Наличности на руках: 1.06 Сообщения: 27 Откуда: tunisia
ASUS GL502VM It is possible to disable gtx1060? there is a solution for that? I have tried to remove the components on this picture, but no result.
Boglen
Заголовок сообщения: Re: G502VM (GL502VM rev 2.0) It is possible to disable gtx1060
No. This laptop doesn't have an integrated graphics, only nvidia. For what the reason you'd removed all of this? There is a boardview for that mb and from them you can see that edp lines connected to the gpu directly.
amd-k
Добавлено: 17 сен 2020, 23:08
as i know, this model also had intel hd graphics I removed the components because they are linked with nvidia on the boardview. thanks for the information about the edp lines
Boglen
Да, немного в заблуждение ввел - в процессорах-то графика есть, но конкретно в этой серии ноутбуков асус встроенное видео даже близко не разводил. ---------- Добавлено спустя 4 минуты 19 секунд: ---------- amd-k as darthmaulx3 clarified i7-6700HQ i7-7700HQ have integrated video core, but in "GL502/702" Asus laptop series manufacturer doesn't ever foresaw an intel gfx support.
Сейчас этот форум просматривают: Algonk и гости: 72
