Текущее время: 21 май 2024, 15:17
 Заголовок сообщения: Asus Strix GTX980 TI - memory fault?
СообщениеДобавлено: 07 окт 2020, 01:01
Hello there.
I've got Asus Strix as per post title, with Samsung memory.
Card takes quite long to start up, but when it starts it will work fine in bios, but once windows drivers are loaded it will throw white artifacts and turns the display off. When used with onboard GPU, Strix will give error code 43.
When tested with MATS it will give me this in report:
Testing GM200 with 20 MB of memory starting with 0 MB.
Errors found. Use -matsinfo for details.
This message will only appear once.
SUBPART RANK0 RD ERR RANK0 WR ERR UNKNOWN ERR
FBIOA[ 31: 0] 0 0 0
FBIOA[ 63: 32] 0 0 0
FBIOB[ 31: 0] 0 0 0
FBIOB[ 63: 32] 0 0 0
FBIOC[ 31: 0] 0 0 0
FBIOC[ 63: 32] 0 0 0
FBIOD[ 31: 0] 0 1315264 0
FBIOD[ 63: 32] 0 1315680 0
FBIOE[ 31: 0] 0 0 0
FBIOE[ 63: 32] 0 0 0
FBIOF[ 31: 0] 0 0 0
FBIOF[ 63: 32] 0 0 0
Rank 0 Failing bits:
D000 D001 D002 D003 D004 D005 D006 D007 D008 D009 D010 D011 D012 D013 D014 D015
D016 D017 D018 D019 D020 D021 D022 D023 D024 D025 D026 D027 D028 D029 D030 D031
D032 D033 D034 D035 D036 D037 D038 D039 D040 D041 D042 D043 D044 D045 D046 D047
D048 D049 D050 D051 D052 D053 D054 D055 D056 D057 D058 D059 D060 D061 D062 D063
Read Error Count: 0
Write Error Count: 2630944
Unknown Error Count: 0
Where do you think problem might be?
P.S. Card was never repaired before and there's no missing components or any visible damage to it.
Thank you for all suggestions :co_ol:
 Заголовок сообщения: Re: Asus Strix GTX980 TI - memory fault?
СообщениеДобавлено: 07 окт 2020, 10:51
Just to clarify, I know that I can replace two memory banks, I have them waiting, but just wanted to make sure it's the most possible reason for this kind of faults.
СообщениеДобавлено: 09 окт 2020, 00:32
Ok, so after replacing two memory banks nothing changed. Exactly the same number of errors appear in mats. I guess that problem is in GPU itself, but I'm not sure.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus GTX980 Strix 4GB нет изо, определяется
doomsayer
14 июн 2021, 01:59
В этой теме нет новых непрочитанных сообщений. Strix GTX980 нет питания памяти
mcloud
01 фев 2023, 17:28
mcloud Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GTX1070 Founders - no Memory Voltage, with external Memory-Power all fine
Assassin
23 авг 2020, 23:26
Assassin Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 1070 mobile MSI, memory all error memory
PT-AH
23 сен 2022, 05:42
black7705 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS G73SW (ASUS G73SW-1BTY) bios fault
underbirdbga
16 авг 2014, 21:50
underbirdbga Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 33
