Текущее время: 06 май 2024, 16:38
9milton
Заголовок сообщения: Help ID sot23-6 chip with marking 1052U Добавлено: 23 окт 2020, 02:36 |
Сообщения: 10 Откуда: England
Help ID sot23-6 chip with marking 1052U motherboard is Nvidia Shield TV 2017 Вложение: 1052U-sot23-6.jpg
mia
Заголовок сообщения: Re: Help ID sot23-6 chip with marking 1052U Добавлено: 23 окт 2020, 08:52 |
Зарегистрирован: 14 сен 2018, 18:14 Наличности на руках: 1,279.27
Сообщения: 2529 Откуда: Odesa,Ukraine
https://cdn.slashgear.com/wp-content/up ... 49x720.jpgThe difference with yours is in the last two digits, so you need to search for 105 Q16 - maybe transistor Drawing a circuit through the conductors of the printed circuit board will help to understand the functional purpose.
9milton
Заголовок сообщения: Re: Help ID sot23-6 chip with marking 1052U Добавлено: 31 окт 2020, 15:54 |
thanks mia mia писал(а): Drawing a circuit through the conductors of the printed circuit board will help to understand the functional purpose. where i have put 18v is from a working board. that board has the same markings 1052U. Вложение: connections.jpg
9milton
Заголовок сообщения: Re: Help ID sot23-6 chip with marking 1052U Добавлено: 01 ноя 2020, 07:07 |
thanks mia for the links. i think it's the APM2605C how would i be able to get these values from the good working board. RDS(ON), Voltage, Current looking at this board you can see the circled chip says M052 or M053 (image not clear) Вложение: shield_teardown.jpg checking Aliexpress i got APM2605C Marking:M052 https://www.aliexpress.com/item/4000233681729.html
9milton
Заголовок сообщения: Re: Help ID sot23-6 chip with marking 1052U Добавлено: 03 ноя 2020, 03:34 |
I ordered the ones from the aliexpress link. also what do you think of this as equivalent? DMP3050LVT
9milton
Заголовок сообщения: Re: Help ID sot23-6 chip with marking 1052U Добавлено: 06 дек 2020, 21:25 |
update on repair. M052 chip came and replaced, still getting hot. the i started to look under the metal shields and found 1 faulty capacitor. replaced the capacitor and the board is working now. so thanks mia for helping me to identify that chip marking. behind USB ports. my board has 4 caps Вложение: cap.jpg other board has 8 caps Вложение: EAxXSxu.jpg
