Текущее время: 28 апр 2024, 15:31
aleksros
Заголовок сообщения: Re: msi 970a -g43 Добавлено: 17 дек 2020, 19:27 |
Зарегистрирован: 26 ноя 2011, 01:09 Наличности на руках: 2,610.26
Сообщения: 4473 Откуда: Киев
bokin021 писал(а): 43 ohm south bridge is dead. will revive)) remove the radiator from it and take a photo of the bridge in good quality. do not wash or clean it.
aleksros
Заголовок сообщения: Re: msi 970a -g43 Добавлено: 18 дек 2020, 11:58 |
aleksros писал(а): remove the radiator from it and take a photo of the bridge in good quality. well, if the mountain does not go to Mohammed, then Mohammed goes to the mountain remove the radiator from the south bridge, clean everything from the oxides that are on the ceramic capacitors. take off the one highlighted in red. put in a new battery and get a working board.
aleksros
Заголовок сообщения: Re: msi 970a -g43 Добавлено: 20 дек 2020, 20:11 |
bokin021 писал(а): I cant install windows at all 10 and 7 i try all .. It is very easy to find a malfunction - you assemble the PC on fully serviceable components and install Windows without errors. After that, install your processor on this PC, which you are not sure about. if an error appears, then the processor is defective. if there are no errors during testing, then one by one install other components from the PC on which the IRQL_NOT_LESS_OR_EQUAL error appears.
