Текущее время: 04 май 2024, 00:07
 Заголовок сообщения: Acer F5-573G (Quanta ZAA) bios request
СообщениеДобавлено: 28 ноя 2019, 23:17
bios request
they deleted the old one
original file no
:ne_vi_del:
http://eximage.ru/image.php?di=3TG8
http://eximage.ru/image.php?di=ADHV
http://eximage.ru/image.php?di=8E7H
 Заголовок сообщения: Re: acer (f5-573g) bios request
СообщениеДобавлено: 29 ноя 2019, 01:08
In bios topic: viewtopic.php?p=561973#p561973
In official site: https://www.acer.com/ac/ru/RU/content/s ... t/6739?b=1
 Заголовок сообщения: Re: Acer F5-573G (Quanta ZAA) bios request
СообщениеДобавлено: 29 ноя 2019, 02:33
I downloaded several files from vlab but it didn't work
old bios deleted
acer bios in their sites 17mb 18 mb hxd came out confused with couldn't get out
СообщениеДобавлено: 23 дек 2019, 11:57
helppppp meeeeeeeeeeeeeeee :bra_vo:
СообщениеДобавлено: 23 дек 2019, 13:56
Aspire F5-573G TESTED OK.rar --- this one was reported as not working, but give it a try.
The other two might work.
When you read old BIOS off your chip you shouldn't be getting any errors, otherwise it would indicate you have a bad chip.
Make it a necessary step for yourself, whenever you take sht apart, read BIOS dump, save it, upload it, share it.
Just make sure when you upload sht, that you upload it to none paying sites.
So that it's not necessary to register and pay in order to download. That's your position right now, because if none of the above works, there are only paid options left for you.
СообщениеДобавлено: 23 дек 2019, 21:55
2 bios .013 amper
F5-573G ZAA2 ME_CLEAN the screen does darken with this bios, but no image 0.50-0.70 between
СообщениеДобавлено: 24 дек 2019, 00:28
bios .013 amper
You see, it's been said before that image is late but it does work...
[QUOTE=bilen;894644]late image but is work . thank you friend.[/QUOTE]
Also was said that ME is clean and you force the EC to reset and accept new ME changing using FPT tool.
[QUOTE=SMDFlea;894646]The ME is clean,if it still has a late image after a reboot you can force the EC to reset and accept the new ME changes using FPT Flash Programming Tool. Run the command:
fpt -greset[/QUOTE]
СообщениеДобавлено: 08 янв 2020, 12:29
problem could not be solved :smu:sche_nie:
subject can be turned off
СообщениеДобавлено: 20 янв 2021, 13:14
слит с рабочего аппарата
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. E5-575 (Quanta ZAA DAZAAMB16E0 (ZAA X32)) Нет изображение.
Мухриддин
1767
28 апр 2022, 15:59
Мухриддин Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer aspire F5-573G (Quanta ZAA X32) Подбор комбайна
makar303
22 окт 2018, 21:12
makar303 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. F5-573G (Quanta ZAA) совместимость комбайнов
Seven
1757
05 фев 2019, 07:27
Seven Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. F5-573G (ZAA X32 (ZAAA) DAZAAMB16E0 Rev : E) биос и процессор
oniandr
1389
14 дек 2022, 14:05
Woldemarius Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer E5-573G (E5-573G) Шипит звук
savjen
2652
15 янв 2016, 20:38
savjen Перейти к последнему сообщению
Сейчас этот форум просматривают: Yandex [BOT] и гости: 36
