Текущее время: 19 май 2024, 06:18
 Заголовок сообщения: Replacement SMD capacitors for ASUS ROG Strix 2080
СообщениеДобавлено: 02 мар 2021, 04:16
Hi, I need to replace 2 SMD capacitors that got burnt on my board (current capacitors in place aren't original spec).
They both are on the PCI-express 12 volt rail (don't mind the part joined capacitor on the second picture near the shunt resistor, it needs soldering properly).
I don't know what voltage and capacitance these capacitors should have - they are circled in red, one in each picture attached.
Any ideas on original spec or any suggestions for what spec would work?
Thanks.
 Заголовок сообщения: Re: Replacement SMD capacitors for ASUS ROG Strix 2080
СообщениеДобавлено: 02 мар 2021, 19:59
first foto - 0.1u*16v
second foto - 4.7u*16v
СообщениеДобавлено: 02 мар 2021, 22:04
Hi, thanks for your response. Sorry I can't see my original photos on this forum.
I've labelled the photos here, could you please clarify which capacitor for which number photo?
And to confirm, that's "u" as in microfarad yes?
Thanks again.
 Заголовок сообщения: Re: Replacement SMD capacitors for ASUS ROG Strix 2080  [РЕШЕНО]
СообщениеДобавлено: 03 мар 2021, 11:57
2 - 0.1microfarad *16v
1 - 4.7microfarad *16v
СообщениеДобавлено: 04 мар 2021, 00:38
That's great, thanks aleksros!
Just curious, how did you determine those values?
СообщениеДобавлено: 04 мар 2021, 00:45
from schematics
СообщениеДобавлено: 05 мар 2021, 02:52
you wouldn't happen to know where to get schematics for this particular board would you?
СообщениеДобавлено: 10 мар 2021, 00:35
aleksros писал(а):
from schematics
Parts installed and shorted MOSFET repaired. Thanks.
В этой теме нет новых непрочитанных сообщений. GTX 970 Palit Broken SMD capacitors
xxkachellxx
859
02 апр 2021, 00:13
acidwise Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Aorus x570 Gigabyte broken SMD capacitors
в форуме Gigabyte
xxkachellxx
25 дек 2021, 20:50
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Idenitfy component on shorted rail ASUS ROG Strix 2080
MSIGamer72
07 мар 2021, 15:31
MSIGamer72 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Identify components and short on ASUS ROG Strix RTX 2080
MSIGamer72
10 мар 2021, 00:33
В этой теме нет новых непрочитанных сообщений. ASUS ROG Strix 2080 repair
MSIGamer72
20 июн 2021, 11:19
