Текущее время: 29 май 2024, 15:04
Micchaleq
Заголовок сообщения: Asus RTX 2080 Ti Turbo - 100% fan and no signal. Добавлено: 05 май 2021, 22:46 |
Зарегистрирован: 21 июл 2018, 10:32 Наличности на руках: 57.41
Сообщения: 39 Откуда: England
Hi all,
I have a question about the problem as in the subject of the post. I have checked all coild by multimeter and toy osciloscope. It look like everything is ok. There is 1,8V 1V, 0,8 GPU and 1,4 VRAM present. The resistance is about: 0,1-0,2Ohm on GPU, 16Ohm on VRAM, 2,8 kOhm on 1,8V; 8 Ohm on 1V 3x 12V kOhm
If you preffer you can answer in your native language.
