Текущее время: 02 июн 2024, 13:39
 Заголовок сообщения: Dell Alienware 17 R4 (LA-D751P) Hang/Freeze on load
СообщениеДобавлено: 12 май 2021, 06:46
Hi
this laptop came working perfectly in Bios/Dos but hangs/freeze on loads, like loading the OS or trying to boot from any media that will put some load on the system..
I've 100% confirmed it's a CPU power problem because disabling intel speedstep or enabling overclocking capabilities option in the bios will lead to a no display startup till resetting bios settings..
I've disassembled the laptop and found burning marks on PL501 inductor and PU502 "SiC632CD" isn't perfectly aligned/soldered, so it looks like the laptop came from a failed repair attempt, I don't know if they replaced PU502 before or it was just waved.. I'll replace all of them and replace PL501 inductor but my question is:
- I have a bunch of NCP302045 chips, are they compatible and can replace SiC632CD ?
- If not, are SiC631 compatible ?
I'm a bit confused in the datasheets :zvez_ochki:
here's a photo found on the web with identical problems on the same platform with the same burnt/failed PL501 inductor !
looks like it's a common thing on this platform:
sorry can't add images, here is a link: https://i.redd.it/cvt4wwlcvcy11.jpg
I'll post mine soon
 Заголовок сообщения: Re: Dell Alienware 17 R4 (LA-D751P) Hang/Freeze on load
СообщениеДобавлено: 12 май 2021, 14:20
Oh wait... :sh_ok:
Surprisingly under the microscope I've found broken solder connections everywhere on all 5 SiC632 chips at the CPU and all 4 chips at the video graphics !
removed all of them, cleaned and refreshed all the pads and chips and put them back, replaced burned PL501 and the system loads perfectly :ya_hoo_oo:
problem solved, but will keep this topic opened to answer the compatibility question
В этой теме нет новых непрочитанных сообщений. DELL Alienware (LA-D751P) залитый номиналы резисторов
в форуме Dell
Nurbek_kz
24 апр 2019, 14:04
Nurbek_kz Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. DELL Alienware 17 R4 (LA-D751p) BIOS
в форуме Dell
Belebirda
13
3000
04 дек 2020, 17:54
Belebirda Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. DELL Alienware 17 R4 (LA-D751p) не поднимает +VCC_CORE и +VCCGT
в форуме Dell
sneper
17 июн 2021, 13:59
sneper Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Alienware r4 17 (La-d751p) Пост код 22
в форуме Dell
ShowMeYourSkills
1624
08 сен 2021, 12:03
khvkdv Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Alienware 17 r4 (LA-D751P) При запуске пропадает напряжение CPU
в форуме Dell
Vishnya
1584
26 окт 2021, 10:25
Сейчас этот форум просматривают: AlexT.. и гости: 4
