Текущее время: 30 май 2024, 19:19
 Заголовок сообщения: Asus RX580 Dual 8GB SMU load firmware failed
СообщениеДобавлено: 12 май 2021, 22:21
Hi,
I have a Asus Dual RX580 8GB with Hynix memory and cannot figure out what is the problem with the card, it fails at driver init with:
[ 6.941275] amdgpu: [powerplay] SMU load firmware failed
[ 6.941303] amdgpu: [powerplay] fw load failed
[ 6.941321] smu firmware loading failed
[ 6.941340] amdgpu 0000:03:00.0: amdgpu_device_ip_init failed
[ 6.941364] amdgpu 0000:03:00.0: Fatal error during GPU init
Till now I didn't encounter this problem and I am trying to get a second opinion before starting to unsolder stuff of the board.
I already replaced the BIOS chip, flashed multiple bioses, no results. All voltages are there and thinks look overall ok.
I'am not sure what this SMU is, from my knowledge the only firmware on the card is the bios, there is no other chip that has a flash.
The main question is if the GPU chip is dead or maybe I should look somewhere else before calling it dead.
Thanks!
 Заголовок сообщения: Re: Asus RX580 Dual 8GB SMU load firmware failed
СообщениеДобавлено: 12 май 2021, 22:41
Осциллографом посмотреть читается ли биос
СообщениеДобавлено: 12 май 2021, 23:20
Voltages can fool you. Measure resistance and you'll see
СообщениеДобавлено: 12 май 2021, 23:39
Hi Seminenko,
I can read the flash using amdflash on both windows and linux, also program it. I already changed the BIOS chip to make sure it's good.
Currently my scope has died and the new one should arrive in a couple of days.
@westcoast: resistances look good, similar to other cards. I don't have an exact same card to compare but very close to other brands.
Thanks!
СообщениеДобавлено: 12 май 2021, 23:43
Check PM. Do you have "failed to send message 254 ret is 0" line in dmesg?
В этой теме нет новых непрочитанных сообщений. XFX rx580 8gb crashes under load
Opacky
10 июн 2022, 22:25
Opacky Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. DMGG/tserver test result ' Failed to load ME microcode using toollib on Tonga / Ellesmere"
wkholi
11 сен 2021, 14:16
ilie321 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ThinkPad T15 Gen 2 (NM-D351 Rev. : 1.0) Failed to recover ME Firmware
Kacher
28 апр 2024, 23:40
В этой теме нет новых непрочитанных сообщений. Замена GPU RX580 на RX480 (ASUS DUAL-RX580-4G)
dyukoldyu
03 май 2021, 18:58
RLS Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. KVA2 RTX 2060 Super 8GB - Artifacts only without load
klugec
06 фев 2024, 15:07
klugec Перейти к последнему сообщению
Сейчас этот форум просматривают: 787, dc64dc64, eugkov, madking и гости: 17
