Текущее время: 19 май 2024, 13:45
 Заголовок сообщения: Hartke system transient attack amplifier model 3500 connected to wrong voltage
СообщениеДобавлено: 26 июн 2021, 16:50
I had the 110 voltage switch and the user ended up turning on 220v
Opening the amplifier you only notice that the 100uF/200 capacitor that feeds the 12ax7 tube is slightly bloated. I took advantage and tested all the power transistors of the audio output but I didn't find any shorted. You may have to change this capacitor (C411) and maybe the 12ax7 valve. The voltage of 10v that came out of the secondary transformer of the power supply feeds the filament of the valve, if it was connected to 220v this voltage was for 20v the same as the 200v which was close to 400v. I need to pass the budget on to the client. If I have to change this valve, where can I find this quality and affordable valve?
 Заголовок сообщения: Re: Hartke system transient attack amplifier model 3500 connected to wrong voltage
СообщениеДобавлено: 26 июн 2021, 17:53
As of 2018 versions of the 12AX7/ECC83 are available from the following manufacturers:
In China: Shuguang and Quanzhen Electron Tube Technology (sold as TJ FullMusic[7])
In Russia: New Sensor, which produces tubes under the Sovtek, Electro-Harmonix, Svetlana, Tung-Sol, and Mullard brands
In Slovakia: JJ Electronic (annual production of approximately two million units)
https://en.wikipedia.org/wiki/12AX7#Manufacturers
https://www.amplifiedparts.com/tech-art ... made-tubes
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GTX1070 GPU GP104 wrong reading of the core voltage NVVDD
karlan
03 мар 2023, 18:53
karlan Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. notebook dell vostro 3500 (Dell Vostro 3500 056tk2 10865) heats up and turns off after a few seconds
в форуме Dell
eletmoraes
28 апр 2018, 02:11
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. svd1121p2eb (mbx 271) platform attack detected
в форуме Sony
ayad
04 мар 2015, 10:26
ayad Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. eMachines E732G (DA0ZRCMB6C0) G1442 mono amplifier
djemileo
13 май 2020, 11:24
djemileo Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Aspire 5715Z (Intel Crestline-GML GL960) upgrade... cpu shut down under attack
DR.Cruncher
13 мар 2021, 09:14
