seminenko писал(а):
Reset pciex, cpu, ddr.
Биос вычитывается?
Сопротивления по data usb?
Readings at usb connectors are good, diode readings are normal and ohms readings are about 1.5 Mohms.
PLT_RST# and DRAMRST#_R are both high level.
FBB_CMD5 (reset signal for video rams (U7301 to U7304)) is always at low level. (measured at pin 1 of R7321)****
What pciex signal should I test?
Thanks for your help.
****(probably due to not post being completed)
