Текущее время: 11 июн 2024, 05:40
 Заголовок сообщения: Lenovo 330-15IKB (LV315KB) No POST when screen is connected
СообщениеДобавлено: 17 авг 2021, 10:57
Hi there!
I have a LV315KB which doesn't post. Fans turns on but there is no keyboard led (caps).
When I take the screen off it post fine (because I have caps led).
It won't post with any screen connected, LVDS, HDMI or VGA.
Voltage in VCCGT is 0v, but if I remove the coil computer will not post in any way (so some verifications are in place saying it is good)
In the AOZ5049QI I have PWM, VIN, VCC, and i don't have FCCM.
I changed the AOZ5049QI (PU4802) but got no change.
I also did a clean ME and got no change.
I don't know what to do.
 Заголовок сообщения: Re: Lenovo 330-15IKB (LV315KB) No POST when screen is connected
СообщениеДобавлено: 17 авг 2021, 15:44
Try to change LCD Cable.
СообщениеДобавлено: 17 авг 2021, 16:11
changed PU4803 ?
bootstrapping kabylake can without vccgt .
СообщениеДобавлено: 17 авг 2021, 19:11
But the problem happens whenever there is any type of display connected to it, even with the LCD cable taken off and an external monitor connected to it.
jonpim писал(а):
changed PU4803 ?
It is not present on the board
But if you say it can do without vccgt, maybe I am facing other issue. But it is strange that it only boots when it has not to deal with any kind of display
СообщениеДобавлено: 17 авг 2021, 20:39
https://www.google.com/url?sa=t&rct=j&q ... rmxDj3Ih3G
High impedance on the input of FCCM will shutdown both HS and LS MOSFETs
does the boot work (pin 3 PU4702 , PC4701 , PR4703 ) ?
В этой теме нет новых непрочитанных сообщений. blue screen with onboard video when I have rx 580 connected to the motherboard
TheMArcos
03 авг 2020, 08:32
mia Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo v130-15IKB (lv315kb) Нужен дамп MAIN биос
rexypower
05 окт 2019, 14:06
rexypower Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo V330-15IKB (LV315KB) Опознать элемент
LaM0
1741
20 ноя 2020, 19:42
LaM0 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo V330-15IKB (LV315KB) Помогите найти номинал резисторов
Jeans
04 фев 2021, 15:28
Pavel Panchev Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo V330-15IKB (LV315KB MB 17807 - 3M) Помогите опознать элемент или найти похожую схему
Alex Goodman
26 дек 2020, 13:28
Leo_vrn Перейти к последнему сообщению
