Текущее время: 05 июл 2024, 10:40
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 20 авг 2021, 12:20 |
![Аватара пользователя](./download/file.php?avatar=110596_1583820810.jpg) |
Зарегистрирован: 27 фев 2020, 13:07 Наличности на руках: 305.76 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 297 Откуда: romania
Hello for those interested here it is 32gb image from my test hdd : https://mega.nz/file/E1h1HS6a#l3u5OOCgx ... sTc_rC9Ragrestore it with diskgenius it has last dmgg and mats ans most of tserver versions; if you need to add more version tserver or mats just copy them in the same folder near the existing ones with diskgenius if is not booting use restore boot with the boot-repair-disk-64bit.iso (you can put this image with Rufus on a usb drive ) https://sourceforge.net/projects/boot-repair-cd/if you use restore boot open your hdd/usb with diskgenius and you need to copy grub.cfg to /boot/grub/ right click on grub.cfg -delete file directly then drag and drop the attached grub.cfg in that place and copy it Вложение: grub.zip unzip first :) now you can boot -1 is for dmgg.py and tserver and it is working as before; example: python3 ./dmgg.py c0000000 1 16 300 (300 is optional and is frequency ) -2 is for mats . it will start test with 455.127 and 4MB but you can use 'ls' command and then select the version you want; for mats you will boot directly in 455.127 and report.txt will open after 3 second after the test is done if for some unknown reason you want to go in graphical mode for linux first option after you enter in console mode just type 'startx' and wait there is also a user called sh and its password is 1 ;you can log in it opening second console (alt f2) and log in
Последний раз редактировалось ilie321 20 авг 2021, 14:51, всего редактировалось 2 раз(а).
![](images/spacer.gif) |
ОхотниК
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 20 авг 2021, 13:47 |
Участник АСЦ |
![Участник АСЦ Участник АСЦ](./images/ranks/cool/ASC.gif) |
![Аватара пользователя](./download/file.php?avatar=401_1283983565.jpg) |
Зарегистрирован: 08 авг 2010, 12:25 Наличности на руках: 307.21 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 130 Откуда: Самара
ilie321 писал(а): Hello for those interested here it is 32gb image from my test hdd :https://mega.nz/file/wkxCDQKT#_xtCfmVK3zRJ983mQjmgzViQ48l0G-dUZmOdd3K7yt0 restore it with diskgenius Ссылка ведет на файл grub.cfg, не образ. Поправьте пожалуйста. ---------- Добавлено спустя 37 минут 45 секунд: ---------- hashwood писал(а): Я получаю это сообщение, что не так?
Я уже отписывался по такому сообщению, вкратце была не допаяна банка, то есть неконтакт чипа с памятью может такое сообщение выдавать.
_________________ Ремонт ноутбуков и видеокарт в Самаре. 8 (906) 125 02 17
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 20 авг 2021, 14:51 |
ОхотниК писал(а): Ссылка ведет на файл grub.cfg, не образ. Поправьте пожалуйста. thanks ; done
crocodile70
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 21 авг 2021, 01:16 |
Зарегистрирован: 31 май 2020, 23:55 Наличности на руках: 433.63 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 632 Откуда: Украина Днепр
ilie321 писал(а): thanks ; done there is a test for rx6800 in your image ?
Pandemonium6
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 23 авг 2021, 16:28 |
![Аватара пользователя](./download/file.php?avatar=124162_1628375555.jpg) |
Зарегистрирован: 22 июл 2021, 03:06 Наличности на руках: 1,139.72 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 761 Откуда: Holand
Воробей писал(а): nope, my friend and also some strangers prooved working. It does work from the mechanical HDD but I can't boot it from the SSD. I used the same SSD before with your images and it worked. I discovered that many files inside the image have wrong permissions, for example they have +x (executable). It looks like you copied many files from Windows or something like a FAT file system. Maybe this is the problem?
theLeXX
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 24 авг 2021, 14:27 |
Зарегистрирован: 07 мар 2021, 18:01 Наличности на руках: 2.01 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 35 Откуда: Сочи
serega2014Mog писал(а): найди в ютубе канал vik-on таб будут ссылки на гугл диск там было эх .. там только начиная с 470 и выше.... для старых ничего нет .. нужно для r9 tahiti... есть у кого ссылка ? или может что-то с этим имиджем надо сделать ?
Gas_man
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 24 авг 2021, 17:43 |
Зарегистрирован: 31 янв 2019, 21:09 Наличности на руках: 390.39 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 305 Откуда: Чебоксары
theLeXX писал(а): нужно для r9 tahiti... есть у кого ссылка ? Тебе нужно искать 2.pmf и 5.pmf. На ТServer тоже есть тесты на старые карты
karlan
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 25 авг 2021, 09:57 |
Зарегистрирован: 06 апр 2021, 23:10 Наличности на руках: 6.36 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 52 Откуда: germany
Воробей писал(а): hmm... i'd say try to tweak voltages, also, are they fine ? like if memory controller gets lower power on lower cloks, but way less then required there is a dedicaded phase for memory controller inside gpu [it's often located near pci-e slot], try to play with it. might give some results the memory controller is a IR35201 and I can measure Vmem_ctr between 900mV at min load to 950mV at max load while in the BIOS it should be between 750mV@300MHz to 950mV@2000MHz I know that with Polaris the minimum Vmem_ctr value has to be always less than the Vcore, but it isn't in my case so this could be the problem. To check it I increased the Vcore at low frequencies to be at least 900mV (but not at 300MHz that cannot be changed and still has to remain at 750mV) but the card still doesn't work properly. I will try to change the BIOS to have always at least 900mV on Vcore The VRMtool would have been usefull here but it is not compatible with the IR35201 I did another thread because here we are maybe out of thema viewtopic.php?f=48&t=117391
Воробей
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 26 авг 2021, 15:15 |
![Аватара пользователя](./download/file.php?avatar=110163_1689533287.png) |
Зарегистрирован: 09 фев 2020, 22:33 Наличности на руках: 52.54 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 90 Откуда: Жлобин
Pandemonium6 писал(а): for example they have +x (executable). just chmodded all in root... i'm so dumb LoL
![](data:image/gif;base64,R0lGODlhCQAJAMQfAIqZyoGSxv3+/trl84CQxYCRxn6PxMXQ7efq9H+Pwtnk8oKTxoCQxKy44QAAANvl9rvG6fD5/o2by4GRxvb8//v9//7+/ubw+v39/ouayoKSxoOTx/7+/wwMDP///////yH5BAEAAB8ALAAAAAAJAAkAAAU84AdoGkNmX4Z4HldRirSxXMdF1zK7nXU9mk2t4+h0BIlNhWPpYTCBDQXXwRwggczgJ8BAGhLRZGIoEFAhADs=)
nneeeet
---------- Добавлено спустя 1 минуту 43 секунды: ---------- theLeXX писал(а): или может что-то с этим имиджем надо сделать ? dmgg?
Pandemonium6
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 26 авг 2021, 19:57 |
Воробей писал(а): just chmodded all in root... i'm so dumb LoL Hehe there is something what prevents loading system from a certain media. It was good before. The image does not have afree space - almost no free space. You could remove the whole xwindows subsystem and some other servers which are not needed. You will save some GB of space. But remember, the UBUNTU is from Canonical with embedded spyware and "cooperation" with Amazon and others. Just have it in mind. Use pure debian or any other light weight linux such 0.5GB in size. No need to put the whole system on the pendrive.
Воробей
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 28 авг 2021, 18:58 |
Pandemonium6 писал(а): No need to put the whole system on the pendrive. maybe one day will, i'm now busy and lazy
ОхотниК
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 30 авг 2021, 00:58 |
Участник АСЦ |
hAdy994 писал(а): ./agt - mem=1000 неправильно!, должно быть так: ./agt -mem=1000и только потом уже вводить команды для tserver
hAdy994
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 30 авг 2021, 02:29 |
Зарегистрирован: 29 май 2021, 01:43 Наличности на руках: 52.00 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 26 Откуда: Lebanon
Pandemonium6 писал(а): ./agt -h It will give you the list of sets of commands. And then you must select what you want to do. You have voltage commands, clock commands and so on. I tried ./agt -mem=1000 and it still didn't work! even with ./agt -mem=1000, running ./tserver -boardtest=memfa gives me the same error "can't find mem= value" ilie321 писал(а): Hello for those interested here it is 32gb image from my test hdd : https://mega.nz/file/E1h1HS6a#l3u5OOCgx ... sTc_rC9Rag Anyone got a backup link for this file? Mega.nz requires a subscription just to download the file otherwise I have to wait 1 hour between every 4GB of data downloaded! Google drive does it for free lol! Posted after 2 hours 39 minutes 28 seconds:Can you please also upload grub.zip to google drive? I need 15 messages...
Gas_man
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 02 сен 2021, 18:58 |
leonvn писал(а): Графические тесты (S3DTest), например STD004.001 выдаёт ошибку. Тестировалось через райзер? как мне объяснял всему уважаемый @GalkinVV - цитирую "тесты gen3 (или как вы пишите S3DTest) - это тесты шины PCIe в режиме 3.0. Они могут не проходить по куче факторов, типа "в материнке принудительно выставлено 2.0" или "слишком длинный райзер" и т.п. Если эксплуатироавть в режиме PCIe 1.1 или PCIe 2.0 - то оно может спокойно не проходить" leonvn писал(а): На экране в Фурмарке артефакты. Артефакты какого рода? Хотя бы фото прицепили! ломанные кривые - Это ГПУ. полоски - квадратики - можно побороться.... leonvn писал(а): Тесты памяти проходят нормально. Частоты повышали?
leonvn
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 02 сен 2021, 21:37 |
Зарегистрирован: 12 апр 2012, 06:21 Наличности на руках: 54.70 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 123 Откуда: Новотроицк
Gas_man писал(а): Тестировалось через райзер? как мне объяснял всему уважаемый @GalkinVV - цитирую "тесты gen3 (или как вы пишите S3DTest) - это тесты шины PCIe в режиме 3.0. Напрямую в плату карта вставлена. Плата какая то АМ2, так что шина там 2.0 не выше. И тесты эти именно 3D тесты, да и картинка соответствующая выводится, типа игрушки. Gas_man писал(а): Артефакты какого рода? Хотя бы фото прицепили! ломанные кривые - Это ГПУ. Про фото не подумал может позже сделаю. Ломанные кривые.
_________________ Флюс Ersa 0FMKANC32 (SW32) https://vlab.su/viewtopic.php?f=109&t=136977
Pandemonium6
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 07 сен 2021, 10:47 |
Gas_man писал(а): Tell me, those in the know, is this the end of the chip? I have a lot of such cards im my inventory. Last week I repaired only 3 cards. All other cards were garbage. Even yesterday I had a card with faulty 1 data line of the C0 memory chip on rx580. I replaced the memory and no change, the same bit of the data line reported by a tserver.
westcoast
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 07 сен 2021, 12:58 |
Зарегистрирован: 01 окт 2020, 02:15 Наличности на руках: 129.19 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 160 Откуда: europe
Gas_man писал(а): Since this topic is devoted to diagnosing banks (chips) of GDDR5 memory for video cards. I decided to post here information that helps me understand the state of the dismantled memory from donors. Measurements for SAMSUNG cans were made by me.
Image resized to 97% of its original size [360 x 198]
The measurements for the HYNIX cans were taken from the telegram channels from MIKHAI (like from @ Mihey3)
Image resized to 97% of its original size [360 x 223]
These measurements were taken from donors, they launched the card and kept the frequencies in the flesh up to 1980 MHz. I took measurements "Voltage drops - continuity" "Black probe" - "-" "Red probe" - "+" Who has any comments and clarifications. I ask you to make the indicated measurements on new memory chips and post the values.
K4G80325FB-HC22 there is 12.5 - 13.5 kOhm on VDDQ in diode mode new chip has 200 on VDDQ and 82 on VDD used chip has 196 on VDDQ and 78 on VDD
