Текущее время: 03 май 2024, 01:09
thrinrot
Заголовок сообщения: GIGABYTE GeForce GTX 1060 OC 6GB Добавлено: 13 сен 2021, 11:56 |
Зарегистрирован: 09 сен 2021, 21:06 Наличности на руках: 10.01
Сообщения: 10 Откуда: Germany
Hi everyone, I bought a GIGABYTE NVidia GeForce GTX 1060 OC 6GB from ebay which was declared to be "working", unfortunately it is not. A quick check gave me the result: defective Mosfet and burned fuse. I already swapped both and the card started again, but after around 10 minutes under load both components are defective again. The defective Mosfet is a AON6414A. Any further suggestions what I could check? Thanks in advance!
thrinrot
Заголовок сообщения: Re: GIGABYTE GeForce GTX 1060 OC 6GB Добавлено: 13 сен 2021, 12:58 |
Thanks! I think i found the drivers. The label says "AZK". It should be a NCP5901B then or am I wrong? There are four of them mounted on the back. Is there a way to check if it is defective?
TomaszR
Заголовок сообщения: Re: GIGABYTE GeForce GTX 1060 OC 6GB Добавлено: 13 сен 2021, 13:24 |
Зарегистрирован: 01 фев 2021, 18:45 Наличности на руках: 99.08
Сообщения: 47 Откуда: Poland
thrinrot писал(а): The label says "AZK". It should be a NCP5901B then or am I wrong? yes, you be right Check PWM following the schematic below https://www.onsemi.com/pdf/datasheet/ncp5901b-d.pdfEach driver is responsible for each phase of GPU power. Check the driver that is on the site of damaged mosfet
thrinrot
Заголовок сообщения: Re: GIGABYTE GeForce GTX 1060 OC 6GB Добавлено: 14 сен 2021, 11:45 |
Since I am still a noob in this. Am I correct that I first have to desolder the defective MOSFET and swap the fuse to measure the PWM Signal? Since currently there is still the short circuit due to the defective MOSFET. Sorry for the (maybe) stupid question.
thrinrot
Заголовок сообщения: Re: GIGABYTE GeForce GTX 1060 OC 6GB Добавлено: 16 сен 2021, 12:28 |
First: thanks to all for your advices, unfortunately I did not find time to check it because of wedding preparations. @JooereX: do you have an approximate position of U504 for me? I have no schematics for this board, what makes it hard to find it. Edit: Found it Think I'll do my next repair session on sunday. Ill reply back afterwards what I found out. Thanks so far to everyone of you! I'm still new to this forum but I already like it.
thrinrot
Заголовок сообщения: Re: GIGABYTE GeForce GTX 1060 OC 6GB Добавлено: 23 сен 2021, 19:30 |
JooereX писал(а): Can you please make voltage measurements on the U504? @JooereX I made the measurements. The component markings read 702 H3. Do not know what this 6pin IC is, could not find a datasheet. Voltages are shown upon the picture: @others I found which driver belongs to the defective MOSFET and tried to do measurements on the solder pads of the corresponding MOSFETS, but my oscilloscope simply shows nothing. Unfortunately my scope does not show anything for the other MOSFETS too. Tried to measure between Gate and Source for the higher MOSFETS and also Gate and GND. Since I am a noob in this and it cant be that all MOSFETS are defective: What am I doing wrong?
aleksros
Заголовок сообщения: Re: GIGABYTE GeForce GTX 1060 OC 6GB Добавлено: 23 сен 2021, 21:47 |
Зарегистрирован: 26 ноя 2011, 01:09 Наличности на руках: 2,610.26
Сообщения: 4473 Откуда: Киев
thrinrot писал(а): The component markings read 702 H3. Do not know what this 6pin IC is, could not find a datasheet. it's double n-mosfet 2n7002dw. but it's not element U504, it's element Q30. u504 right side from text "u504" (about picture), it have 5 pins.
