Зарегистрирован: 22 сен 2013, 01:30 Наличности на руках: 6.04 Сообщения: 12 Откуда: london
Hello.
I kindly ask someone who owns this Lenovo ThinkCentre M92z computer or at least its IQ77SN board if they can give me a dump of the U32 ATMEL 24C02 chip (I think it's 24C02 and no higher, notation ATMLH240 02CM) located next to the DP701HDE video signal output IC, under the back USB ports slot.
I accidentally deleted this chip and now the computer starts, the RTC bios beeps but it doesn't display anything anymore. Only the monitor menu works when you press the front buttons.
I know for sure that this is the cause because before it worked, the display was showing, had only one other problem in the bios that I solved.
I can't find this dump anywhere on the net, only MAIN U17 + U36 and EC bios.
I also tested these bioses to see if I can somehow rewrite the 24C02 IC at startup but it doesn't work.
Сейчас этот форум просматривают: Maxmcz и гости: 3
