Текущее время: 18 май 2024, 10:50
 Заголовок сообщения: GTX 1070ti Armor 8gb samsung, error bus, no video and turn on pc teamviwer.
СообщениеДобавлено: 31 окт 2021, 21:59
I have a serious problem with my brother's gpu, the memories are gone. I switched to samsung. Something happens, she starts the pc but does not pass image on the monitor.
using teamviewer it appears, samsung memory appears and neither bus nor bandwidth readings appear.
what could it be?
any resistance that remains to change in the controls?
put in
0 0 0 1 0 0
 Заголовок сообщения: Re: GTX 1070ti Armor 8gb samsung, error bus, no video and turn on pc teamviwer.
СообщениеДобавлено: 31 окт 2021, 22:14
PT-AH
Measure the resistances across all main supplies (picture in attachment)
Check the presence of voltages and the quality of the PWM converters with an oscilloscope.
现在的也越来越难修啊,生意真是不好做啊!
© Конфуций из Шэньчжэня
СообщениеДобавлено: 01 ноя 2021, 19:33
chip GP104-300-A1
but I have a line that has 0 ohms
Link image: https://ibb.co/9cd4HWj
СообщениеДобавлено: 01 ноя 2021, 20:48
PT-AH
If 0.2 Ω is normal, measure further on all power converters.
Your GP:
СообщениеДобавлено: 02 ноя 2021, 06:19
I have been measuring and everything is ok.
it seems to me something with a problem with the bios chip of these readings
СообщениеДобавлено: 02 ноя 2021, 14:37
PT-AH
Leave the bios alone, you can only aggravate the problems :hi_hi_hi:
It is possible you have a problem with PCI-E
Swap PCI-Ex16 slot for PCI-Ex8 or test motherboard for AMD
By running 30 test mods from under the integrated graphics (at least 4GB of RAM) mods will show if you have a problem with PCI-E.
Instructions for using mats-mods here (in Russian but in pictures):
viewtopic.php?p=897863#p897863
Check the presence of all voltages and their quality of operation of the PWM converters with an oscilloscope.
СообщениеДобавлено: 02 ноя 2021, 17:15
I'm going to buy the oscilloscope to deal with it and until then the graph will stay leaning and follow your directions
this repair will be paused...
СообщениеДобавлено: 19 фев 2022, 16:04
Good luck to the whole team.
well I bring here a repair that everyone finds suspicious.
her fault is that she had errors in all memory banks.
I replaced it with new memories.
they told me it was a controller defect, after all this time in analysis I found the error and removed the error. Because there is something that is defective on the PCB that causes this error. It doesn't give as burned, but it also doesn't give as impeccable in terms of values.
also for fun I changed something else that left me the 1070TI with 1911 mhz always, whether playing or benchmarking. But for this I think that for it to be at 100% I will have to change the VRM, because the mosfets scream a little.
in benchmark heaven it always gives above 118 fps while the rx 5600xt goes at its 87 fps.
It seems that not even with raw air OC and with 190W no one has done this...
Memory banks after repair: https://ibb.co/Bzgwd6S
GPU-Z: https://ibb.co/3cKjxPW
bench_fps_test: https://ibb.co/0ZFk3Hq
knowledgeable in these matters, will it work?
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. X230 Won't turn on (X230 Won't turn on) X230 Won't turn on
zenelli
26 сен 2015, 06:25
Arrester Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS X555LD turn on with abnormal fan spin and turn off
kandyan
04 мар 2022, 09:55
kandyan Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba A210-15K (6050A2127101-MB-A02 ) ERROR Resource Conflict – PCI Seral Bus Controller on Motherboard
в форуме Toshiba
akmal_rt
28 окт 2015, 14:22
akmal_rt Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. sony vaio PCG-7F4P (M/B : DA0RD1MB8D0 rev: D) ERROR PARITY CONFLICT BUS
в форуме Sony
eletmoraes
20 июл 2020, 23:52
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. mods pc express bus error
jedelmo123
05 июн 2022, 10:11
jedelmo123 Перейти к последнему сообщению
Сейчас этот форум просматривают: psyche, SKP161 и гости: 15
