Текущее время: 14 май 2024, 02:47
 Заголовок сообщения: Xfx 470 8gb - bios problem (clock 0 memory 0)
СообщениеДобавлено: 09 дек 2021, 10:53
Good morning
I hope my English is pretty good.
I have an xfx 470 8gb with black fans, received from a friend, who tried to change his bios, but unfortunately did not save a backup to the original bios.
I took the original bios from another identical video card. I uploaded it using the ch341a program
But the video card does not have clock and memory in windows or in hiveos (linux)
Windows - https://i.imgur.com/OEu4bIm.png
Linux - https://i.imgur.com/zVLzd6D.png
 Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0)
СообщениеДобавлено: 09 дек 2021, 11:46
If the driver won't be installed then it will show 0 gpu clock and 0 memory clock.
If it happened after after bios update then the software of bios will be faulty.
try to flash this bios and tell us about the result.
https://www.techpowerup.com/vgabios/209440/209440
СообщениеДобавлено: 09 дек 2021, 12:36
I installed the driver 10 times. I deleted it completely, then reinstalled it.
I mention that I still have an rx 470 xfx 8gb that it works.
I've already uploaded that bios from the link. And I've tested others and they look the same.
I tried to upload the bios through the hiveos, but the same problem.
 Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0)  [РЕШЕНО]
СообщениеДобавлено: 09 дек 2021, 18:29
check memory manufacturer before flashing bios
В этой теме нет новых непрочитанных сообщений. Xfx 470 8gb - bios problem (clock 0 memory 0)
alynut991
28
3755
16 фев 2022, 13:59
Pandemonium6 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. XFX RX580 8GB with memory speed problem
karlan
22
2818
18 янв 2023, 14:03
karlan Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Fujitsu LifeBook NH532 (Intel i5 3230m Nvidia 640m LE) Problem with RAM memory , also Problem with Graphic dri
в форуме Fujitsu-Siemens
draganzile
01 авг 2016, 18:08
draganzile Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. XFX RX 580 XXX 8GB memory resistance
nikolavik
1198
21 фев 2022, 23:38
nikolavik Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. msi rx470 armor 8gb memory problem
amkwca
27 дек 2021, 05:19
Сейчас этот форум просматривают: crocodile70 и гости: 14
