Текущее время: 17 июн 2024, 07:28
 Заголовок сообщения: Gigabyte rx480 gaming g1
СообщениеДобавлено: 18 дек 2021, 17:24
I'm getting 1.8v missing on that card. I ckecked GS7103 linear regulator it has vdd and vin but missing the signal enable. I followed the signal should come from a transistor MMBT3904 S1AH and replaced but still no enable volt. replaced the Ic, same result. I measured resistance from pin En to ground, it's 0.7 k and I believe it's supposed to be 10k, I checked all resistors and capacitors in range to find a faulty one but didn't find. Anybody can help?
 Заголовок сообщения: Re: Gigabyte rx480 gaming g1
СообщениеДобавлено: 18 дек 2021, 19:08
What is the resistance on 1.8V itself?
СообщениеДобавлено: 18 дек 2021, 21:48
I think it's normal. it's 3.9 k from 1.8v pin and ground. any idea?
СообщениеДобавлено: 19 дек 2021, 00:31
open schematic or boardview and find enable
СообщениеДобавлено: 19 дек 2021, 03:01
I don't have schematic for that card but enable comes from the dual transistor and I changed it with no results
СообщениеДобавлено: 19 дек 2021, 06:59
There is schematic for RX-590 and looks the same as you describe on page 21 here:
Gigabyte GV-RX590 GME-8GD Rev: 1.0 Схема
viewtopic.php?f=48&t=2118
Page has description (19) POWER MANAGEMENT
The same regulator and the same NPN transistor
СообщениеДобавлено: 19 дек 2021, 08:42
I tried something now, I should share with you. I put external power 3.3v to pin EN from a bench power supply and I tried the card on the motherboard and measured volts, I'm having now the 3.3v at pin EN and accordingly I got 1.8v at pin 7 finally. I measured volts after, I'm getting PEX volt 0.9v and I'm still missing vcore, vram and v ram controller. Any idea? I'm so exited
СообщениеДобавлено: 19 дек 2021, 15:11
amkwca
bardview in privat message. it's from msi but similar ))
take for us foto your card from bottom side near U300 and Q210 Q1010
СообщениеДобавлено: 19 дек 2021, 21:30
This schematic is probably good. You have to follow these signals backwards. This 1.8V_EN is formed by at least 3 other circuits built on NPN discrete transistors. You have to follow them all.
В этой теме нет новых непрочитанных сообщений. MSI Radeon RX480 GAMING X 4G определяется, изображения нет, при нагрузке слетает разгон
paxamobil
13
3427
12 мар 2021, 18:52
probe2005klm Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI Radeon RX480 Gaming x 8g
Djonnnik
1974
13 июн 2019, 01:05
Crimfell Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. asus strix rx480 08g gaming подтвердить неисправность гпу
sokolov_yuri
03 май 2021, 19:15
RLS Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI rx480 Gaming X нет питаний кроме 12в
Mirco
924
18 авг 2021, 12:16
Mirco Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus Strix RX480 Gaming 8GB нет питания MEM и GPU
uxmaxi
13 июл 2022, 18:03
uxmaxi Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 12
