Текущее время: 10 май 2024, 00:12
 Заголовок сообщения: XFX RX 580 XXX 8GB memory resistance
СообщениеДобавлено: 06 ноя 2021, 14:22
Hello,
I have problem on XFX RX 580 XXX edition
It will not boot, and not detected.
Every voltage is okey and resistance except for a memory. It show above 200 ohm.
Gpu i check it is have normal heating and i think it is okey.
Is that problem of memory banks or shoud i meassure something else?
Regards
 Заголовок сообщения: Re: XFX RX 580 XXX 8GB memory resistance
СообщениеДобавлено: 07 ноя 2021, 01:35
This is very good question because it is very rare to have higher resistance than lower. What brand of memories is there?
СообщениеДобавлено: 07 ноя 2021, 04:28
Micron memory. I try to remove 2 banks but nothing is change. I don`t bealive if i remove all of them would change anything.
СообщениеДобавлено: 07 ноя 2021, 04:56
I got many times something like 120-130 ohms but the card was working. But never higher. Did you check all other possibilities like PCIe signal integrity? Is this card visible when you do lspci -v ? Just I am curious what is working, is clock running?
СообщениеДобавлено: 07 ноя 2021, 14:31
No. The card is not initialize.
I mesure all resistors compering with another card. I will try to remove all memory just to see is it going to change anything.
СообщениеДобавлено: 07 ноя 2021, 23:51
lspci -v does not need to have this card initialized. Connect is as a secondary and run this command, scroll up.
СообщениеДобавлено: 08 ноя 2021, 20:47
Ok. Will try that.
I try to remove all memory and still the same so not memory for sure.
СообщениеДобавлено: 21 фев 2022, 19:48
Заблокирован
I have this problem also with xfx rx 580. memory voltage is 1.5v but resistance is above 600 ohm, which is high for this kind of card. I measured other working card but there is only 40 ohm resistance. Did you solve this problem?
p.s all voltages are good but the card doesnt boot and the gpu temp is not too hot when poweron
СообщениеДобавлено: 21 фев 2022, 23:38
On that one i didn`t solve a problem. I think GPU problem because i remove all memory and put on another board and it is around 40-50 ohm.
Memory working perfectly.
And i had another similar XFX with high resistance working normal.
В этой теме нет новых непрочитанных сообщений. Помогите опознать сбитый элемент XFX RX-580P8D GTS XXX ED RX 580 8GB OC+
HarleyDavidson78
26 сен 2021, 17:29
eugenekus Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. xfx rx 580 gts XXX ed. 8gb no vcore.
crow84
09 фев 2023, 14:37
crow84 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RX 570 Memory resistance high
dani82
29 ноя 2021, 15:08
dani82 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI/XFX/SAPPHIRE RX 480/580 D0 D1 Memory error
ll_r1d0_ll
842
06 ноя 2022, 13:04
karlan Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. XFX RX580 8GB with memory speed problem
karlan
22
2811
18 янв 2023, 14:03
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 27
