Текущее время: 10 май 2024, 01:17
 Заголовок сообщения: saphire nitro rx5700xt tserver ?
СообщениеДобавлено: 16 мар 2022, 14:11
Заблокирован
Is there some vram test tool for saphire nitro rx5700xt model ?I use Tserver from this forum ,but cant test also python dmgg.py (shows 7/8 channel )I have change new memory but show same ..I thing some fault with software...Maybe some can share information for test this card?Thanks
 Заголовок сообщения: Re: saphire nitro rx5700xt tserver ?
СообщениеДобавлено: 17 мар 2022, 08:53
bokin021 писал(а):
I use Tserver
Have you tried an image with a menu like this ? :du_ma_et:
viewtopic.php?f=48&t=123675
Вооружён и не опасен :ps_ih: 1) Тепловизор Seek Thermal UW-AAA для Android ; 2) Микроскоп с HDMI выходом Eakins ; 3) Блок питания LW 3010D DC 30V 10A ( к райзеру + провода 8+8pin для питания видеокарты ); 4) Станция Gordak 863 3 в 1 ; 5) Мультиметр UT61B ; 6) Программатор MiniPro TL866CS 7) Осциллограф Hantek DSO5102P .
СообщениеДобавлено: 17 мар 2022, 10:39
Заблокирован
yes same i have ..
Posted after 2 hours 18 minutes 32 seconds:
My tserver
СообщениеДобавлено: 17 мар 2022, 13:46
bokin021 писал(а):
yes same i have
He writes that there is a new version of linux OS :-) "Ubuntu 20.04.4 LTS", and did you enter the commands to run the test? Everything is on the Internet.
СообщениеДобавлено: 17 мар 2022, 14:14
Заблокирован
I run test ,but does not run ..How i can upgrade linux I should download new vram tool or?
Posted after 1 hour 32 minutes 39 seconds:
I did (do-release-upgrade)but after this command I got black screen I can't see update process..What I doing wrong?
СообщениеДобавлено: 18 мар 2022, 02:42
Firstly: I do not write that an update is available, Secondly: I have an error that the files are not found
Reasons why it doesn't download /find updates:
1) Sanctions on Russia (blocking) - that's why he writes that the file was not found 404
2) There is not enough disk space, which is unlikely!
I checked on my Asus RX 5500 XT 8Gb Dual-RX 5500 X TO 8 GEVO graphics card - I also have a black screen :du_ma_et:
cd rx55003
./tserver -boardtset=memfa
Most likely this is a problem with the script as in the video of a Person (VIKon / VIKoff) https://www.youtube.com/watch?v=SIpIOyv023E
But you are testing the rx5700xt, and I tested the rx5500 xt 8gb - and the result is one "Black screen" :ne_vi_del:
After a while I tried as in this video https://www.youtube.com/watch?v=Lg5Wgjb8Rdg change the memory frequency. Entered the value ./agt -mem=1750
He entered the value ./agt -mem=1750 and writes me the default frequency of 875.00 MHz and the current frequency of 0.00 MHz (which is incorrect). I enter the command ./agt -mem= and he writes to me already 875.00 MHz and the current frequency of 875.00 MHz (what is right for my graphics card / 875*2=1750 MHz)
Then I enter the command ./tserver -boardtest=memfa there is no black screen and stops there (there is no inscription PASS - although the video card is working) :sh_ok:
СообщениеДобавлено: 18 мар 2022, 12:20
Заблокирован
Look my pictures ..
СообщениеДобавлено: 18 мар 2022, 16:52
bokin021 писал(а):
Look my pictures ..
I looked, just like me, but I have a serviceable RX 5500 XT 8Gb video card (but there is no Pass inscription), and you have rx5700xt (but there is a Fail inscription). Here I do not know, maybe someone else will answer. BUT THE BLACK SCREEN could go :-):
СообщениеДобавлено: 18 мар 2022, 18:21
Заблокирован
I thing something wrong is with memory it's written 256mb..
СообщениеДобавлено: 20 мар 2022, 21:39
Заблокирован
I found some link ,and i wonder what tserver he use..
https://www.youtube.com/watch?v=zNHMDCM7Cg8
http://188.34.147.90/Asus/Tools/VGA/VGA ... e_2021.pdf
In this PDF I found what we need ,but when i wanted download say that my country does not support RMA ..Maybe ther is way for download
One more on radeon site
https://www.amd.com/en/support/kb/relea ... inux-20-50
СообщениеДобавлено: 21 мар 2022, 01:57
That's ok for this cards, the memory channels are not counting the same.
Try to reball gpu, if not the card is dead.
Test is NOT working with graphic cards who are stucked at b2 code
СообщениеДобавлено: 08 апр 2022, 01:44
bokin021 писал(а):
I have exactly the same faulty card as yours in my hands. Tserver's memfa doesn't work but AGT works and gives the same result as on your picture -mccfg.
My card stops at B2 and bios restarts after 20 seconds. All resistances and voltages are perfect.
СообщениеДобавлено: 21 янв 2024, 23:11
Я не могу получить доступ к USB, чтобы проверить карту VGA
В этой теме нет новых непрочитанных сообщений. tserver rx5700xt
frankmnld
16 май 2022, 09:41
YunicheK Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. XFX RX5700XT + tserver
JooereX
1900
29 ноя 2022, 22:06
allas Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sapphiro nitro Radeon RX5700XT 8G не работают вентиляторы.
AlexNaz
591
12 фев 2024, 06:09
AlexNaz Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Saphire nitro rx 470 4 gb
Martovitskiy_Aleksey
08 авг 2019, 16:36
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Saphire Nitro R7 370 4G DDR5 (299-1e321-500sa) Нужна Схема
lucky13
25 окт 2016, 15:27
lucky13 Перейти к последнему сообщению
Сейчас этот форум просматривают: Kototip, lexgreem, Lflash и гости: 26
