Текущее время: 17 май 2024, 14:54
 Заголовок сообщения: AMD VEGA VII = ERROR 43, Questions!
СообщениеДобавлено: 22 май 2022, 23:48
I have here with me an AMD RX VEGA VII.
I would like to know if anyone here has one too.
I don't have the same boardviewer.
But I would like to understand something like:
Impedance of the memories (ohms) in the circuit.
(current = 16 ohms).
But I remember that the Vega 56 has 60 ohms.
but this one has twice as many memories.
what I find most strange is that the gpu-z has no frequency on the graphics chip. But I think I have something to block.
In this case, I know that the chip frequency is worked simultaneously with the graphics chip internally.
Voltages I have 1.2V on the HMB2 and the rest are all OK
Video link VRM: https://www.youtube.com/watch?v=zx9rKmsxk00
Is there any part of the chip that can check frequencies with an oscilloscope?
I don't mind offering donations for great help
 Заголовок сообщения: Re: AMD VEGA VII = ERROR 43, Questions!
СообщениеДобавлено: 24 май 2022, 01:01
I have 5 of these Radeon VII sitting around waiting for repair.... would love to join you on your journey as these seem to be quite the enigma
СообщениеДобавлено: 24 май 2022, 01:52
well amd only makes riddles.
Amd being kind of silly, but they love to join memory frequency to improve chip frequencies and take advantage of both. But when it gives 1 error it's a giant problem.
If you want to start:
The first point is to know how much the inductance of the HMB2 memories gives you in all of them.
then we follow the rest.
СообщениеДобавлено: 27 май 2022, 02:14
photo = https://imgur.com/a/d1Hgp57
Hello
I come here to ask, but I think it's not normal to have only 1 of the power phases with PWM wave in the coil.
as well as the memory also only has 1 with PWM.
already all other circuits are correct, measuring on the oscilloscope.
Could the fault be wrong here?
 Заголовок сообщения: Re: AMD VEGA VII = ERROR 43, Questions!  [РЕШЕНО]
СообщениеДобавлено: 27 май 2022, 16:25
There are two malfunctions on the vegas. 1 burnout
2 gpu died
В этой теме нет новых непрочитанных сообщений. куплю неисправные vega 56 vega 64 референс
в форуме Куплю | Buy
naroznyv
17 ноя 2021, 23:45
naroznyv Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. AMD RADEON VII. Виснет на B2.
Sergey183
19 май 2021, 10:33
Sergey183 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. WTH. Amd VII ir35217x2 register map
Pcmaccaroni
09 апр 2022, 18:32
Pcmaccaroni Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Amd vii shim firmware
Pcmaccaroni
12 апр 2022, 23:58
В этой теме нет новых непрочитанных сообщений. AMD Radeon VII - отсутствует питания VDDCR_GFX, SoC и VDDCI
RandomR
31 май 2023, 10:46
RandomR Перейти к последнему сообщению
Сейчас этот форум просматривают: 787, RTEZ, Sa1FeR, VetalPOLT, Vyacheslav007, YunicheK и гости: 26
