Текущее время: 01 май 2024, 02:40
 Заголовок сообщения: lenovo ibm code error interpretation  [РЕШЕНО]
СообщениеДобавлено: 01 фев 2013, 17:18
IBM Desktop Beep code
No beep:::::::::::::::::::::::::::::::::::::::::::::::::::::::::: No power, loose expansion card (ISA, PCI, or AGP), a short, or an improperly grounded motherboard
1 short:::::::::::::::::::::::::::::::::::::::::::::::::: System OK
1 long:::::::::::::::::::::::::::::::::::::::::::::::::::::::: Video/display problem; video card incorrectly seated or defective
2 short::::::::::::::::::::::::::::::::::::::::::::::::::::::: POST Error displayed on monitor
3 long:::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: Problem with 3270 keyboard card
1 long, 1 short:::::::::::::::::::::::::::::::::::::::::::::::::::::::Problem with system board
1 long, 2 short:::::::::::::::::::::::::::: ::::::::::::::::Problem with display adapter (MDA, CGA)
1 long, 3 short:::::::::::::::::::::::::::::::::::::::::::::::::::::::Problem with EGA
Repeating short beeps:::::::::::::::::::::::::::::::::::::::::::Problem with power supply or system board
Continuous beep:::::::::::::::::::::::::::::::::::::::::::::::::::Problem with power supply or system board
IBM Thinkpad beeps code laptop
Continuous beeping::::::::::::::::::::::::::::::::::::::::::::::: System board failure
1 beep with blank display:::::::::::::::::::::::::::::::::::::::::::: LCD connector problem, LCD backlight inverter failure, video adapter failure, or LCD assembly failure
1 beep w/message "Unable to access boot source":::::::::::: Boot device failure or bad system board
1 long, 2 short:::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: System board, video adapter, or LCD assembly failure
1 long, 4 short:::::::::::::::::::::::::::::::::::::::::::::::::::::::::: Low battery voltage
1 beep every second::::::::::::::::::::::::::::::::::::::::::::: Low battery voltage
2 short w/message:::::::::::::::::::::::::::::::::::::::::::::::::: Read the error message on the display
2 short with blank display:::::::::::::::::::::::::::::::::::::::: System board failure
В этой теме нет новых непрочитанных сообщений. IBM T500 (IBM) Unlock password bios IBM T500
way1412
23 сен 2015, 10:27
В этой теме нет новых непрочитанных сообщений. help for measurement and interpretation
seegras
01 май 2021, 16:34
seegras Перейти к последнему сообщению
seegras
02 май 2021, 10:38
vikrep Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo V580C Ошибка 0271 Real Time Error. Fan Error
inferno3086
03 июн 2020, 15:53
inferno3086 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Сервер IBM System x3550 M4 Express (7914K1G) ошибка 0x 2 unrecognised progress code
Suta
4405
19 дек 2018, 15:42
Suta Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 34
