Текущее время: 21 май 2024, 11:51
 Заголовок сообщения: RTX 2080 Video_TDR_Failure
СообщениеДобавлено: 25 июл 2021, 20:31
hi everyone, this is the first time I write on this forum and it is mainly in Russian so forgive me if I make any mistakes.
I have an RTX 2080 video card that is driving me crazy, at first it had the classic screen white stripes sign of corrupted memory, I used "mats" and replaced the malfunctioning memory bank, the card started working but showed slight artifacts, decreasing the memory frequency the artifacts disappeared so I thought of another broken memory bank not detected by mats, it has already happened to me with a couple of 2070s, I thought of solving as I did for the other boards, i.e. reflowing all the memory banks usually the malfunctioning memory bank breaks permanently and is detected by mats, again this time it happened but this last bank was replaced, the card has stopped working, when it loads the drivers on windows the screen goes black with the VIDEO_TDR_FAILURE error. i tried changin the bios chip and flashing different bios and i also successfully reballed the gpu but the problem remains. i dont think the core is the problem since it loaded before. Has anyone ever encountered a similar problem?
other information, all the voltages are present, the card does not load the drivers even in the PCI_E x8 slot, and I have checked all the data lines and the capacitors of the data lines on the back. Mats не обнаруживают ошибок
RUSSIAN (google traslator)
Привет всем, я впервые пишу на этом форуме и в основном на русском, так что простите меня, если я допущу какие-либо ошибки.
У меня есть видеокарта RTX 2080, которая сводит меня с ума, сначала на ней были классические белые полосы на экране, признак испорченной памяти, я использовал «маты» и заменил неисправный банк памяти, карта начала работать, но показывала небольшие артефакты, уменьшая частота памяти артефакты исчезли, поэтому я подумал о другом сломанном банке памяти, не обнаруженном матами, это уже случилось со мной с парой 2070-х годов, я думал о решении, как и для других плат, т.е. перекомпоновка всех банков памяти обычно неисправный банк памяти постоянно ломается и обнаруживается матами, опять же, на этот раз это произошло, но этот последний банк был заменен, карта перестала работать, когда она загружает драйверы в Windows, экран становится черным с VIDEO_TDR_FAILURE ошибка. Я попытался заменить чип BIOS и перепрограммировать другой BIOS, и я также успешно перебалансировал графический процессор, но проблема остается. Я не думаю, что проблема в ядре, так как оно загружалось раньше. Кто нибудь сталкивался с подобной проблемой?
прочая информация, все напряжения присутствуют, карта не загружает драйверы даже в слот PCI_E x8, и я проверил все линии данных и конденсаторы линий данных на задней панели. Mats не обнаруживают ошибок
 Заголовок сообщения: Re: RTX 2080 Video_TDR_Failure
СообщениеДобавлено: 01 июн 2022, 21:47
https://youtu.be/IxZ3p0k_tgE look here
him use MATS-MODS 426
СообщениеДобавлено: 01 июн 2022, 21:58
Маркировка чипов памяти какая?
В этой теме нет новых непрочитанных сообщений. m6-1263 (LA-8711P Rev: 1.0) video tdr failure
COWAND
24 май 2020, 15:47
COWAND Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Converter Rtx 2070s im Rtx 2080
TheMArcos
15 ноя 2020, 23:09
nemos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Predator Triton 500 Predator (Wistron Ghibli 18803-SC) Change GPU rtx 2060 to rtx 2080?
pcexpert8
25 сен 2022, 23:08
pcexpert8 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Сканер Magellan 9800 не запускается порт TDR
Rostyk.07
17 июл 2020, 14:16
Rostyk.07 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Quiero comprar un osciloscopio para reparar tarjeta de video RTX 3000, RTX 2000. ¿Que osciloscopio recomiendan
azzed
01 фев 2023, 20:31
azzed Перейти к последнему сообщению
Сейчас этот форум просматривают: Анатолий68, daa_sasha, Redkaya Svolo4 и гости: 37
