Текущее время: 27 май 2024, 21:10
 Заголовок сообщения: Sapphire Pulse RX 550 2GB error code 43
СообщениеДобавлено: 13 июн 2022, 14:29
Hello everyone. I am sorry for writing in english as I dont know russian. I find this forum very helpful in repairing.
I am new into repairing GPUs. I have Sapphire Pulse RX 550 sealed card from a shopkeeper. He said that the gpu never show display from the first day it was opened from box for a client. It is detected in device manager with ERROR CODE 43. If i install it as PRIMARY Display, it is stuck on post code B2. When I run TSERVER on it, it hangs. All voltages are present on gpu. 1.35V is present for memory. Resistance of memories (ELPIDA) is 50-60 Ohms. I have tried to flash bios but that did not help. I dont know what else should I check. Some help from professional people here will be great. Thanks ! :-):
 Заголовок сообщения: Re: Sapphire Pulse RX 550 2GB error code 43
СообщениеДобавлено: 14 июн 2022, 12:54
Have you checked with different versions of tserver? Maybe for some other rx5xx card?
СообщениеДобавлено: 14 июн 2022, 19:04
how is the bios pulse?
СообщениеДобавлено: 16 июн 2022, 02:07
Hi . No i did not try with any other version of TSERVER. I have done from the tserver provided in IMAGE with MATS and TSERVER and WINDOWS included.
I have tried 2 different bios but still same B2 Error. Gpu was sealed and opened by me and looked totally clean from inside except for rubbish paste . Should i reflow gpu or reball vrams ?
СообщениеДобавлено: 16 июн 2022, 13:55
That should be your last resort... I advise you to try different tserver tests... Maybe for rx570 or 580 to see if you get different results.
СообщениеДобавлено: 17 июн 2022, 05:16
Thanks. I will look into it and update results here.
СообщениеДобавлено: 19 июн 2022, 02:06
Tried with different versions of tserver. Tserver hangs :( . NO LUCK
СообщениеДобавлено: 27 июн 2022, 20:02
Have you checked basics? Pciex lines caps and pex reset?
СообщениеДобавлено: 06 июл 2022, 11:01
Yes unfortunately no luck.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sapphire Pulse RX 550 2gb нужен оригинальный биос
JooereX
14 дек 2021, 04:25
JooereX Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sapphire Pulse RX 550 2GB (11268-03) помогите узнать номиналы
Elfy
12 янв 2023, 11:05
Elfy Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sapphire RX 550 pulse 4gb (512) Low Profile - нет изображения
VileDog
03 мар 2022, 01:51
vladnig Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Опознать номиналы залитика Sapphire PULSE RX 550 4G G5 LP.
Random smd
27 янв 2023, 16:06
Random smd Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sapphire Pulse Radeon RX550 2Gb опознать элемент
Lflash
14 апр 2018, 10:04
Сейчас этот форум просматривают: Yandex [BOT] и гости: 16
