Текущее время: 17 май 2024, 14:57
 Заголовок сообщения: RTX 2080 no display
СообщениеДобавлено: 15 авг 2022, 10:40
Hello
I have Rtx 2080 and the problem is explained below.
Gpu boots up and works perfectly on load without any issue. But when i turn off my computer and turn on again after short time it do not gives display.
When i turn on pc after 8 to 10 hours it gives display and works again perfectly.
Its passing Mats and not giving errors on any memory bank.
Please tell me what could be the problem with my gpu.
 Заголовок сообщения: Re: RTX 2080 no display
СообщениеДобавлено: 15 авг 2022, 15:23
Bad bios chip maybe?
СообщениеДобавлено: 15 авг 2022, 15:50
I also suspect bios chip. Is there any way to check it before replacement?
Posted after 2 hours 35 minutes 49 seconds:
I checked with multimeter while no display it gives 3.2v on 5v inductor.
СообщениеДобавлено: 16 авг 2022, 09:19
So now you know where to look. Check 5v convertor and everything around it for possible problem.
СообщениеДобавлено: 16 авг 2022, 11:25
3.2v on 5v rail and short on pex.
СообщениеДобавлено: 19 авг 2022, 13:54
Are you sure that you are measuring everything correctly? What is pex resistance?
СообщениеДобавлено: 30 авг 2022, 20:57
You don't have to replace the vBIOS chip. You can hook it to a CH341A and a test clip to read the contents and compare them to some vBIOS image on the internet. But first I recommend you to check if everything is being powered with the correct voltage. Perhaps you have a bad chip.
Posted after 1 hour 11 minutes 34 seconds:
I searched around the internet and found a BIOS file. I'll attach it. If you are gonna flash it, please backup the content on the chip, it is very important if my file doesn't work.
В этой теме нет новых непрочитанных сообщений. Converter Rtx 2070s im Rtx 2080
TheMArcos
15 ноя 2020, 23:09
nemos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Predator Triton 500 Predator (Wistron Ghibli 18803-SC) Change GPU rtx 2060 to rtx 2080?
pcexpert8
25 сен 2022, 23:08
pcexpert8 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. RTX 2080 SUPER
azatar0890
2804
01 ноя 2019, 10:57
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Palit RTX 2080 Артефакты, ждем патч МОДСА?
azatar0890
2003
26 ноя 2019, 11:01
virus-cyber Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI RTX 2080 Ti Lightning RGB подсветка не работает
Mamania
2602
14 май 2020, 13:18
Сейчас этот форум просматривают: 787, ruslan1111, Sa1FeR, SKP161, smomlik, VetalPOLT, Vyacheslav007, YunicheK и гости: 29
