Текущее время: 09 май 2024, 05:36
 Заголовок сообщения: MSI GE62 7RD Apache (MS-16J91) Error in graphics memory with chips and without chips
СообщениеДобавлено: 04 сен 2022, 16:41
Hello again, I'm going crazy with this laptop, it's an MSI GE62 7RD apache (MS-16J91) with i7 gen 7 processor and GTX 1050 graphics card (not Ti).
They gave me this laptop with a short circuit in the 19v input mosfet, I replaced the mosfet and the laptop works perfectly, but the dedicated graphics card gives error 43 in windows and when I do the diagnosis with Mats (400,250) it tells me that errors in the vram modules A1 and B1.
After this I replaced the A1 and B1 modules, I did the diagnosis again with mats and it gives me the same error again, but if I do the diagnosis again for the second time it only gives me an error in the A1 module, if I turn off the computer and I carry out the diagnosis again, the error returns in A1 and B1, I carry out a second diagnosis and it only marks an error in A1.
Finally, I unsoldered the A0 and A1 modules and after carrying out the diagnosis, it continues to show an error in A1 and B1 and in the second diagnosis, an error only in A1 (all this without having soldered the chips)
First test without A0 and A1 chips
Цитата:
mats version 400.250. Testing GP107 with 1 MB of memory starting with 0 MB.
Read Error Count: 16418
Write Error Count: 621790
Unknown Error Count: 0
=== MEMORY ERRORS BY SUBPARTITION ===
SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
FBIOA0 0 0 0
FBIOA1 8194 490750 0
FBIOB0 0 0 0
FBIOB1 8224 131040 0
Failing Bits:
A032 A033 A034 A035 A036 A037 A038 A039 A040 A041 A042 A043 A044 A045 A046 A047
A048 A049 A050 A051 A052 A053 A054 A055 A056 A057 A058 A059 A060 A061 A062 A063
B032 B033 B034 B035 B036 B037 B038 B039 B040 B041 B042 B043 B044 B045 B046 B047
B048 B049 B050 B051 B052 B053 B054 B055 B056 B057 B058 B059 B060 B061 B062 B063
Second test without chips A0 and A1
Read Error Count: 0
Write Error Count: 498944
FBIOA0 0 0 0
FBIOA1 0 498944 0
FBIOB0 0 0 0
FBIOB1 0 0 0
Failing Bits:
 Заголовок сообщения: Re: MSI GE62 7RD Apache (MS-16J91) Error in graphics memory with chips and without chips
СообщениеДобавлено: 07 сен 2022, 02:27
Any ideas?
СообщениеДобавлено: 07 сен 2022, 19:20
Hello!
Take a photo of your chip and memory.
and on the photo mark your numbering of defective memory chips.
if everything was done correctly, it is possible that the GPU was dumped.
Or the memory controller in the GPU has failed.
You can still get confused, the memory and GPU are removed. then call from memory to GPU.
Sorry for my english, it's not at all =)))
Он был на столько не удачлив, что выпаивал с донорских плат конденсаторы в "КЗ"
"Паяю, не воняю!"
СообщениеДобавлено: 08 сен 2022, 01:19
Had the same problem with 1050 and mats, also gpu works fine. Try another mats, 367 for example. Also check voltage and vram resistance
СообщениеДобавлено: 09 сен 2022, 06:45
I have desoldered the four vram chips and performed the test, even so it continues to show the same errors, I attach photos
asderoff писал(а):
Posted: 07 Sep 2022, 22:19
The voltages are correct in all the chips and I have also tried version 367 but it gives the same errors, I forgot to mention that the 4 chips are new
СообщениеДобавлено: 29 сен 2022, 12:11
Прошейте новый bios на программаторе, проблема в прошивке может быть.
СообщениеДобавлено: 02 окт 2022, 16:25
ruzalit писал(а):
Flashea una nueva bios en el programador, el problema puede estar en el firmware.
I try it, thanks
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI GE62 6QD APACHE PRO (MS-16J5) нужен дамп биоса
в форуме MSI
sidlan
26 июн 2017, 16:02
DenisGusarov Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 1070 mobile MSI, memory all error memory
PT-AH
23 сен 2022, 05:42
black7705 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI GV62 7RD (ms-16j91) После замены GTX1050 на Ti версию 43 ошибка
в форуме MSI
AhiLL
31 июл 2020, 19:57
AhiLL Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI GV72 7RD (MS-16J91 rev 1.0) Нет инициализации
в форуме MSI
pcm-nn
30 ноя 2020, 18:29
pcm-nn Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GE62 2QL APACHE (MS-16J21) биос
в форуме MSI
joni12341
19 янв 2017, 17:40
joni12341 Перейти к последнему сообщению
Сейчас этот форум просматривают: barbaroja и гости: 4
cron
