Текущее время: 01 ноя 2024, 03:29
 Заголовок сообщения: 15-n (DA0U93MB6D2) No Display
СообщениеДобавлено: 21 сен 2022, 10:43
hi guys
this board has water damage and it was almost dead in first place
i turn it on and now it has all voltages on coils but there is no display. lvds or hdmi
post code is 01
SYS_PWRGD = 1.8V
RSMRST#=3.2V
RSMRST#_R=1.9V
how can i find is it cpu problem or what?
as i make it alive from total death i really want to repair it
ill be grateful of your helps
thanks all
 Заголовок сообщения: Re: 15-n (DA0U93MB6D2) No Display
СообщениеДобавлено: 30 сен 2022, 07:46
Where was the damage in which area ?
measure and post the voltages and resistances across all the coils..
СообщениеДобавлено: 30 сен 2022, 09:25
not enough information. few measurements.
and the resistance of the processor
https://comsystem-tlt.ru/obzori/soproti ... processoro
СообщениеДобавлено: 12 окт 2022, 19:52
water damage was mostly around PU2 that doesn't let it to turn on
and allitle around pu8 (pr121) that doesn't make cpu voltage
i thought SYS_PWRGD = 1.8V means that all voltages are good
also HWPG= 3V
Voltages on all coils are good
resistance for pl16=32ohm and pl11=148
its amd E1 cpu
СообщениеДобавлено: 13 окт 2022, 03:25
Does the voltages rise on PL11 & PL16 ?
if yes, did you try to flash the bios ?
do you have "U18" installed on the board ?
СообщениеДобавлено: 13 окт 2022, 11:19
Does the voltage rise on PL11 & PL16 ?
if yes, did you try to flash the bios?
yes i flash some bioses and same result
PL11=0.90V
PL16=0.84V
no there is no u18
and my board is UMA
СообщениеДобавлено: 15 окт 2022, 04:12
Check the resistance of USB D+,D- lines,
if they are not in low resistance try the attached bios..
В этой теме нет новых непрочитанных сообщений. HP 15-009sr (da0u93mb6d2 rev d) 3 раза мигает светодиод гнезда зарядки
a_artem
2941
09 фев 2018, 17:44
a_artem Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Pavilion 15-n026sr (da0u93mb6d2 rev d) Фризит изображение после установки драйверов видео.
mishanyadj
12 сен 2021, 21:44
mishanyadj Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. 14-n003la (da0u93mb6d2 ) без видео
в форуме Поиск BIOS
crow84
23 апр 2023, 08:46
REM Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. dell 3521 (Display problem help me) Display problem
в форуме Dell
ahmeterengul
12 июн 2017, 11:22
ahmeterengul Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Samsung R540 Bremen-C No display
в форуме Samsung
shijeesh
02 дек 2014, 00:16
gs84 Перейти к последнему сообщению
Сейчас этот форум просматривают: Google [Bot], iosufzv, Itmasters и гости: 103
