Текущее время: 10 май 2024, 06:12
 Заголовок сообщения: RTX 3080ti mods 116й тест "020000116097"
СообщениеДобавлено: 19 ноя 2022, 20:23
ВК даёт изо без артов и прочего, драйвера ставятся без проблем, частично может бегать в 3д нагрузках, вне зависимости от обьёма задействованной памяти
модс выдаёт на 116м тесте следующее (94й и ряд других тестов - норм ходит, и с повышенной памяти на 10% тоже):
log
Running test(s) on GPU 0 [01:00.0] (DID: 0x2208)
Enter SetPState (test 0) Sat Nov 19 17:47:12 2022
Switched to PState 0 (0.max). Pcie Speed=8000, x16
ClkM = 9502.00 MHz
ClkHost = 1350.00 MHz
ClkDisp = 1350.00 MHz
ClkGpc = 1965.00 MHz
ClkXbar = 1860.00 MHz
ClkSys = 1650.00 MHz
ClkHub = 810.00 MHz
ClkPwr = 540.00 MHz
ClkNvd = 1725.00 MHz
ClkPexGen = 3.00
NVVDD = 1081.25 mV
MSVDD = 1075.00 mV
Exit 000000000000 : SetPState (test 0) ok [0.054 seconds]
Enter CudaAppleKHTest (test 116) Sat Nov 19 17:47:12 2022
mods/core/utility/errloggr.cpp: GPU interrupt: MMU Fault : ENGINE_GRAPHICS FAULT_PDE GPCCLIENT_T1_4 ACCESS_TYPE_VIRT_READ
ERROR: cuStreamSynchronize returned error 700 (CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered)
New unexpected HW interrupts have occurred, count = 1 (1 new)
CudaAppleKHTest "Post-Run" callback failed (unexpected device interrupts).
ERROR: cuMemFreeHost returned error 700 (CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered)
ERROR: cuMemFree returned error 700 (CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered)
ERROR: cuEventDestroy returned error 700 (CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered)
ERROR: cuModuleUnload returned error 700 (CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered)
ERROR: cuMODSFreeResourceMemory64 returned error 700 (CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered)
ERROR: cuStreamDestroy returned error 700 (CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered)
CudaAppleKHTest Run ErrCounter::ExitStackFrame failed.
Exit 020000116097 : CudaAppleKHTest (test 116) unexpected device interrupts [989.066 seconds]
Правильно ли понимаю что проблема порылась в кэше? Как то ранее не доводилось такую ошибку наблюдать на ga102
 Заголовок сообщения: Re: RTX 3080ti mods 116й тест "020000116097"
СообщениеДобавлено: 20 ноя 2022, 09:08
Выложите логи полностью. А вообще CUDA-MEMCHECK вам в помощь.
https://docs.nvidia.com/cuda/cuda-memcheck/index.html
СообщениеДобавлено: 20 ноя 2022, 19:28
так а в чем проблема с картой,кроме 116 теста ?
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Palit rtx 3080ti gaming pro криво определяется
dron102
23 авг 2023, 01:07
dron102 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI RTX 3080ti no picture all Voltages up
Dance0fArrows
21 сен 2023, 15:24
Dance0fArrows Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI GeForce RTX 3080ti SUPRIM X ошибка 0xbadf1401
Crimfell
29 янв 2024, 23:31
Crimfell Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Пошаговая инструкция Mods+Mats Тест видеопамяти
[ На страницу: 1 ... 20, 21, 22 ]
marcev174
647
324044
05 май 2024, 01:35
takhirsemenenko Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Помогите правильно запустить тест mats mods 94,178
massimko
21 окт 2023, 18:49
ser51 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 19
