Текущее время: 21 май 2024, 23:54
 Заголовок сообщения: Strix X570E missing component and q code 4d
СообщениеДобавлено: 07 дек 2022, 03:33
Hello comrades, i have an asus x570e. Card was working without VCORE voltage, changed the enable resistor of PWM controller which is ASP1405I, card came back to life but stopped at code 4d. I tried 3600x and 5800x with couple of bioses. Programmed the bios with flasher and also tried with bios flashback option but no luck. Board has a broken component i dont know what it is, i need your help about the component and error code. Thank you a lot .
 Заголовок сообщения: Re: Strix X570E missing component and q code 4d
СообщениеДобавлено: 08 дек 2022, 10:10
Как такое могло быть?
СообщениеДобавлено: 08 дек 2022, 18:13
zaytsevphoto
it was just turning on nothing more :)
СообщениеДобавлено: 14 дек 2022, 10:08
do you have ssd m2 conected when you receive this code?
memory voltage is ok? >=1.2v
СообщениеДобавлено: 14 дек 2022, 15:18
ilie321
no, nothing connected. Only RAM and cpu thats it. I have all voltages between range, 4D related to CPU also CPU light is on when its happen.
СообщениеДобавлено: 14 дек 2022, 22:19
Maybe search for similar boardview try x370 asus boardview or something else. I am new and i cant see photos, sorry. Also, check if vcore voltage is ok and if you have oscilloscope, check pwm signal if normal and if stable vcore and pwm signals. Maybe something else wrong... Measure if enable signal isnt/wasnt shorted previously before you changed resistor, could be bad pwm controller.
СообщениеДобавлено: 15 дек 2022, 11:40
tretecou
Board is working Q codes running. Debug leg also passes dram to cpu and stays there with 4d error code. I cant find anything same from different boards, even X570 TUF does not have it.
СообщениеДобавлено: 27 дек 2022, 05:34
yusuf4511
The left component is in place, the right one is probably the same. And for sure it's dual mosfets. You can check with a multimeter.
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 01 янв 2023, 02:32
RsM
i placed same next to it, card showed same 4d code with or without it.
СообщениеДобавлено: 02 янв 2023, 10:31
Can you provide all measures of resistance by ceramic capacitors on HUB X570?
СообщениеДобавлено: 06 янв 2023, 07:08
sensey
СообщениеДобавлено: 02 фев 2023, 20:28
update : i changed the hub with a brand new one. Everything stayed same
В этой теме нет новых непрочитанных сообщений. lenovo (L460) component and eeprom missing
sebuncle
05 дек 2023, 18:49
sebuncle Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. strix b550-i gaming missing component
ilie321
1170
15 дек 2022, 09:27
ilie321 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. asus k55v (k55VM rev 2.0) Help with missing component ohm
SpinNNN
20 июн 2018, 19:19
В этой теме нет новых непрочитанных сообщений. Broken Aorus GTX 1080ti. Seeking help with missing component
Vazza10
1293
04 фев 2021, 07:22
Vazza10 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Help missing component ASUS RX 570 Expedition | Помогите пропавшему компоненту ASUS RX 570 Expedition
katoda22
08 мар 2021, 21:46
katoda22 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 12
