Текущее время: 12 май 2024, 23:18
 Заголовок сообщения: Dell Inspiron 15-7577 P72F001 (LA-E992P Rev 2.0) No Initialization, possible dead GPU
СообщениеДобавлено: 15 янв 2023, 22:33
Hello,
This board came from a failed repair attempt with symptoms of turning on for 3~5 seconds then off, opened and found 2 missing DrMos chips (PU5201 & PU6101) on +VCCGT & +NVVDD1, I don't know what originally happened there..
Put 2 new chips and the board started with the following:
without RTC battery: Turns on / off / Turns on again and keep going on
Fans runs at full speed
Consumption @ 19.5v = Dancing between 1.0A ~ 1.8A then fall to 0.900A (time from start to stabilize = 17 seconds)
+VCC_CORE = 1.0v @ 2.3 ohm (SR32Q) then fall to 0.66v after 17 seconds
+VCCGT = appears after 17 seconds 0.69v and keep on, resistance is 4.3 ohm
+NVVDD1 = 0.77v @ 0.3 ohm (N17E-G1-A1)
without the cooler, the CPU boils to shutdown before the stabilization while the GPU barely heats-up..
no post card in hand, without RAM the LEDs blinks for RAM codes..
The suspect was the GPU, I doubt 0.3 ohms are normal for this chip right ?
it consumes 0.700A from the LB @ 0.80v and no heat was noticeable
I've inspected the chip under the microscope and found 2 micro-cracks in the corners so I can declare it dead, right ? :ps_ih:
Now I'm fighting to convert it to UMA and need some help..
Removing GPU power PL6101/PL6102/PL6103 & PL801 has no effect except on the power consumption which dropped..
removed PU6000 - nothing
followed the schematics and moved GPU_ID RH551 to RH552, RH553 to RH554
replace SKU_ID RE125 with 10K
replace Board_ID RE13 with 10K
moved Phase_ID RH547 to RH548, RH549 to RH550
moved DGPU_PWR_EN RH129 to RH127
still nothing..
Bios flash clean / official.. nothing
any help ?
should i remove the chip and try or something wrong in converting ?
 Заголовок сообщения: Re: Dell Inspiron 15-7577 P72F001 (LA-E992P Rev 2.0) No Initialization, possible dead GPU
СообщениеДобавлено: 25 янв 2023, 08:07
UPDATE:
*No diagnostic postcard in hands, using USB flash drive with a LED to test initialization...
1- after modding the bios by setting primary display to IGFX (default=SG) there is activity on the USB, activity stops if the drive removed & re-inserted
no caps-lock/num-lock and no screen...
- there wasn't any activity on the USB before trying to convert to UMA, so the the problem is definitely in the discrete graphics and the board didn't fully convert and fully initialize..
- this activity on the USB appeared after 17 seconds (the exact same period mentioned before, so the board is still looking for the dGPU..
2- discovered that driving DGPU_PWR_EN's 10K resistor from (HIGH=RH129) to (LOW=RH127) has no effect and does not pull the signal down ! DGPU_PWR_EN still 3.2v
any ideas ?
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. INSPIRON 15-7577 la-E992P dis не получается залить чистый регион
в форуме Dell
makmain
11 дек 2019, 19:49
makmain Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Inspiron 15-7577 (LA-E992P) Включается только после сброса CMOS
в форуме Dell
lelykgsm
04 янв 2021, 21:13
lelykgsm Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell 7577 (la-e992p ) мертвых
в форуме Dell
Sashamarzor
29 сен 2020, 21:50
Евгений18 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Inspiron 15 Gaming (LA-E992P) not charging
в форуме Dell
BalkanBoy
23 авг 2019, 21:52
BalkanBoy Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. dell Inspiron 15 7577 (la-e991p rev. 1.0) Нет инициализации после замены hm175
в форуме Dell
StayeR
2727
24 янв 2020, 13:31
StayeR Перейти к последнему сообщению
