Текущее время: 03 июн 2024, 13:58
 Заголовок сообщения: Fatal1ty Z370 Gaming-ITX/ac не работает PCIE 16X
СообщениеДобавлено: 22 май 2021, 20:55
Hi sorry I can't speak Russian. The PCIe 16x slot on my motherboard is not working. When I plug in a graphics card the fan spins but then turns off. There is no display on the monitor. What can I do to find the problem?
 Заголовок сообщения: Re: Fatal1ty Z370 Gaming-ITX/ac не работает PCIE 16X
СообщениеДобавлено: 27 май 2021, 12:24
1st - you should write what CPU and GPU do you have.
2nd - Look carefully on motherboard near PCI-e slot and on the CPU socket, pins may be damaged. Left corner
Also you shoud try test another GPU, CPU in your MB and vice versa
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 02 июн 2021, 10:56
I have QTJ2, I have tried Gigabyte GTX 1070 and MSI RTX 3070. These cards work in a different motherboard, so I know the card is not the problem.
CPU socket appears to be okay:
I tried cleaning the pads under the CPU interposer, and now the graphics card fans will spin, however there is still no picture. PCIe slot is detected in Windows, but no graphics card is detected.
It seems like the motherboard chipset is okay, its seems that the signal that needs to tell the motherboard that a graphics card is installed is broken.
СообщениеДобавлено: 02 июн 2021, 13:19
may be check all motherboard for missing smd components?
like this.
СообщениеДобавлено: 06 июн 2021, 22:07
QTJ2 - bios mod must to be done! Or no video will be. Use 4.10 and CoffeTime
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 07 июн 2021, 07:30
I did the bios mod with the following settings
Also version 4.30 BIOS shows 5.12 in CoffeeTime for some reason
СообщениеДобавлено: 07 июн 2021, 14:53
I tried i5 7500 in the motherboard with modified BIOS.
Graphics card is working correctly. I guess there is another setting that needs to be changed for QTJ2
СообщениеДобавлено: 08 июн 2021, 13:02
pseudobacon
Use 4.10 and do PCIe Xeon in it to be green and all will be working. This is the last version which could support mod!
Next time write down all info in 1st post. Your problem is from nothing. Read manual carefully next time!
-приворот winDOвSa
-розыгрыш автоБАНа
 Заголовок сообщения: Re: Fatal1ty Z370 Gaming-ITX/ac не работает PCIE 16X  [РЕШЕНО]
СообщениеДобавлено: 09 июн 2021, 11:59
All working now. Thank you
В этой теме нет новых непрочитанных сообщений. intel dh57dd не работает PCIe 16x
в форуме Intel
GigaBlyate
2858
23 авг 2019, 01:04
pEEp Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI GTX 1050ti не работает PCIE 16X
cheguevara
1275
13 дек 2020, 18:46
uncledim Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GA-H77M-D3H нет 12v в PCIe 16x
в форуме Gigabyte
vdm62
1890
20 сен 2019, 20:17
В этой теме нет новых непрочитанных сообщений. Как проверить PCIE 16X слот
в форуме Asus
tonycstech
919
25 апр 2022, 16:47
pptv Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. 1050Ti KFA2 LP works/работает in PCIE x1 but not/но нет in PCIE X16 (X8)
cxav
24 фев 2023, 20:44
karlan Перейти к последнему сообщению
