Текущее время: 21 ноя 2024, 12:58
 Заголовок сообщения: acer predator g9-593
СообщениеДобавлено: 14 янв 2024, 19:01
Hi everyone, this is my first post and I hope I'm not making a mistake.
I'm struggling with a repair of an acer predator g9-593. It doesn't turn on.
On the RAM coil I have 1 ohm and it doesn't seem normal to me.
Could someone tell me how much more or less it should be?
Thank you.
Posted after 2 hours 47 minutes 40 seconds:
Someone know olso what is the resistence between VDD e VSS in DDR5 modul?
 Заголовок сообщения: Re: acer predator g9-593
СообщениеДобавлено: 15 янв 2024, 02:35
moscat
This is not normal, almost a complete short circuit.
СообщениеДобавлено: 15 янв 2024, 06:27
moscat
первый пост и первая ошибка...нужно указать платформу
viewtopic.php?f=35&t=2206
СообщениеДобавлено: 16 янв 2024, 23:45
I apologize for my impreciseness.
This is a MU5DC/CH7DC REV:2.0 mainboard
СообщениеДобавлено: 17 янв 2024, 07:20
There is no smell of the ddr5 module in this laptop, if measurements are interesting, I can do them in the evening, but 1 ohm is not enough, without memory too? Maybe they just inserted a faulty bar
УГТУ-УПИ , МНИРТИ
СообщениеДобавлено: 18 янв 2024, 01:18
Thanks for the reply. I had 1 ohm with all ram modules soldered. I put them all back and measuring them between Vdd and Vss four measured 60 Ohms and two 1.2 Ohms. However, if I measure the voltage drop towards GND after the Vdd coil of the RAM now I have 5.3 Ohm. I think there is a short in the GPU memory controller. Basically GPU to replace. What do you think about it?
СообщениеДобавлено: 18 янв 2024, 18:58
If you removed the modules, what is the resistance on the board? The resistance may vary depending on the memory modules, but less than 28 ohm I have not seen what memory you have installed? And this is only on the memory power supply.
If the video chip power supply, 1070 normal resistance is 0.4 ohm.
P.s. I wasn't able to take measurements yesterday, I'll try today.
---------- Добавлено спустя 2 часа 14 минут 3 секунды: ----------
If you have any questions, write
УГТУ-УПИ , МНИРТИ
СообщениеДобавлено: 19 янв 2024, 01:09
[img]
After the DRAM coil that I removed (all 6) the Vdd (+VBFDDQ) towards GND (Vss) is now 5.2 ohm. In a boardview of a similar G9-591G mainboard I saw that this Vdd also goes to the GPU and therefore I think this is shorted. Sorry but i don't know how to add a pictures.
В этой теме нет новых непрочитанных сообщений. Acer Predator G9-593 (N/A) Выключается при странных обстоятельствах, стресстесты проходят без проблем
vorob
2077
17 мар 2019, 22:24
vorob Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Acer Predator 15 [G9-593] (Pegatron MU5DC/CH7DC) Включается, есть посты, нет инита
Teodor
20 сен 2019, 13:04
Teodor Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer Predator (g9-593) no ACDET/resistor value?
myth77
17
3281
18 июл 2022, 11:15
mmarc Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. acer predator 15 g9-593 mu5dc ch7dc rev 2.1
в форуме Поиск BIOS
omidhadian
02 фев 2022, 14:53
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. acer predator g9 593 (mu5dc/ch7dc rev 2.0) отключить видеокарту
kaskad33
14 авг 2023, 14:20
kaskad33 Перейти к последнему сообщению
