Текущее время: 15 июн 2024, 22:26
moscat
Заголовок сообщения: Re: acer predator g9-593 Добавлено: 18 янв 2024, 01:18 |
Зарегистрирован: 13 янв 2024, 03:13 Наличности на руках: 19.00
Сообщения: 7 Откуда: Italy
Maksim S писал(а): There is no smell of the ddr5 module in this laptop, if measurements are interesting, I can do them in the evening, but 1 ohm is not enough, without memory too? Maybe they just inserted a faulty bar
Thanks for the reply. I had 1 ohm with all ram modules soldered. I put them all back and measuring them between Vdd and Vss four measured 60 Ohms and two 1.2 Ohms. However, if I measure the voltage drop towards GND after the Vdd coil of the RAM now I have 5.3 Ohm. I think there is a short in the GPU memory controller. Basically GPU to replace. What do you think about it?
moscat
Заголовок сообщения: Re: acer predator g9-593 Добавлено: 19 янв 2024, 01:09 |
[img] Maksim S писал(а): If you removed the modules, what is the resistance on the board? The resistance may vary depending on the memory modules, but less than 28 ohm I have not seen what memory you have installed? And this is only on the memory power supply. If the video chip power supply, 1070 normal resistance is 0.4 ohm. P.s. I wasn't able to take measurements yesterday, I'll try today. After the DRAM coil that I removed (all 6) the Vdd (+VBFDDQ) towards GND (Vss) is now 5.2 ohm. In a boardview of a similar G9-591G mainboard I saw that this Vdd also goes to the GPU and therefore I think this is shorted. Sorry but i don't know how to add a pictures. Thanks for the reply.
