Текущее время: 01 ноя 2026, 06:40
| Автор |
shck
Заголовок сообщения: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 08 июн 2026, 10:47 |
| Я тут случайно |
Зарегистрирован: 23 ноя 2019, 17:32 Наличности на руках: 20.00
Сообщения: 10 Откуда: Севастополь
Добрый день. Прошу помощи знатаков. Испробовал все доступные варианты прошивок с раздела SMI MPTool SM2258 с префиксом L06B c юсбдев.ру. Ничего не вышло.
Лог smi flash id v0.568a
OS: 10.0 build 19045 Drive: 4 Model: USB3.0 Super Speed Fw : 0214 Size : 1019 MB Controller : SM2258AA Bank00: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank01: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank02: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank03: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank04: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank05: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank06: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank07: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank08: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank09: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank10: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank11: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank12: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank13: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank14: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank15: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank16: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank17: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank18: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank19: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank24: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank25: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank26: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Bank27: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Pure Spare Blocks : 0 Running Spare Blocks: 0
Фото устройства
MoneyBot
Заголовок сообщения: ADATA ASU800SS-1TT sata слетела прошивка |
MoneyBot
shck
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 08 июн 2026, 12:37 |
| Я тут случайно |
Rusly59 писал(а): А какой конкретно результат при попытке прошивки?
Я так понял при более менее правильно подобранных настройках висит на "Download Mp Package FW"
Картинки
Rusly59
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 08 июн 2026, 14:53 |
| Интересующийся |
Сообщения: 97 Откуда: Пермь
shck писал(а): висит на "Download Mp Package FW" Вероятно что прошивка не подходит. Память по автодетекту выставляется? ---------- Добавлено спустя 6 минут 58 секунд: ---------- Перебирайте пачку прошивок IM3D для 2258. начните с прошивок Qxxxx
shck
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 08 июн 2026, 15:28 |
| Я тут случайно |
Rusly59 писал(а): Вероятно что прошивка не подходит. Память по автодетекту выставляется? Нет, память сам всегда выбирал "intel 256gb..". Rusly59 писал(а): Перебирайте пачку прошивок IM3D для 2258. начните с прошивок Qxxxx Те тоже пробовал, но не все. Сейчас начинаю..
shck
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 08 июн 2026, 21:07 |
| Я тут случайно |
jonpim писал(а): Если не прошьет - тогда сначала rdt-selftest . Может нанда замучена пока не пойму что это и как делается -) Ваш вариант с прошивками не помог. Либо я что то не так делал. BMA писал(а): А шьёте через что ? SATA ? USB ? Через USB карман(универсальный) в котором был SSD .
shck
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 09 июн 2026, 22:41 |
| Я тут случайно |
Rusly59 писал(а): Лучше использовать карман на контроллере Jmicron, память по автодетекту определять, так нужные параметры мптул сам подгонит.
Как раз таки карман на контроллере Jmicron. А точнее 1 карман, а второй адаптер sata-usb.
карман
https://disk.yandex.ru/i/mZtFihF5AQP_Xw
BMA писал(а): Желательно карман на контроллере JMicron или Asmedia и с прошивкой NoUASP. NoUASP пока не понимаю что такое. Прочту. Если есть конкретно куда ткнуть - ткните пожалуйста:) Предложенные "ДО" варианты не сработали. Может конечно я что то сделал не так потому что это всегда было после 00:00. Но еще попробую, конечно. ---------- Добавлено спустя 4 часа 25 минут 28 секунд: ---------- В итоге завел на 2258XT S0909A0. Обьем 640Гб. Других вариантов пока не вижу.. ---------- Добавлено спустя 33 минуты 43 секунды: ---------- Q0914B дала также 640ГБ но на sata2
Rusly59
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 10 июн 2026, 07:36 |
| Интересующийся |
shck писал(а): В итоге завел на 2258XT S0909A0. Обьем 640Гб. Других вариантов пока не вижу. А если вручную выставить объем, в ошибку валится?
shck
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 10 июн 2026, 10:13 |
| Я тут случайно |
Rusly59 писал(а): А если вручную выставить объем, в ошибку валится? Тогда размечается 200Гб с небольшим и все. Я вот никак не пойму почему ни одна прошивка не подошла для 2258 с буфером. Вообще не хочет вставать. Никак.
SMI_в_ATA_режиме_пишет
Please select drive number:4 Drive: 4(USB) Model: ASU800SS-1TT Fw : S0909A0 Size : 610480 MB [640.1 GB] From smart : [SMI2258XT] [S0909A0 00] [IM00] Controller : SM2258 bufferless FlashID: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die Channel: 4 CE : 6 TotDie : 24 Plane : 4 Die/Ce : 1 Ch map : 0x0F CE map : 0x5F Inter. : 6 First Fblock : 2 Total Fblock : 548 Total Hblock : 9539 Fblock Per Ce : 548 Fblock Per Die: 548 Original Spare Block Count : 40 Vendor Marked Bad Block : 0 Bad Block From Pretest : 27
---------- Добавлено спустя 11 минут 50 секунд: ---------- На прошивках L06B ошибка DRAM size постоянно. Ставлю 128, 256, 512Мб Самсунг. Идут тесты. Ошибка размера памяти ОЗУ "DRAM size.."Ставлю 1024мб Самсунг. Вечный загруз.. "Download Mp Package FW"
Для примера Nanya 1024Мб лог
STEP : Pretest Procedure (0x31) ERROR : Find error from DRAM data. (0x04)
<<<<< Pretest ERROR Analysis >>>>>
(0x13) : Too Much Bad!
--- Total Plane Bad Block numbers for each channel and ce ---
CH 0 1 2 3 CE0 0017 0016 0016 0024 CE1 0020 0012 0019 0016 CE2 0026 0026 0042 0014 CE3 0038 0018 0020 0027 CE4 0032 0017 0017 0026 CE5 0000 0000 0000 0000 CE6 0021 0018 0017 0017 CE7 0000 0000 0000 0000
jonpim
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 10 июн 2026, 10:29 |
| Продвинутый форумчанин |
Зарегистрирован: 26 дек 2010, 14:42 Наличности на руках: 777.93
Сообщения: 2022 Откуда: Vladivostok
shck писал(а): На прошивках L06B ошибка DRAM size постоянно. Так может сам чип DRAM сдох ? Они тоже дохнут , но реже чем нанды .
shck
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 10 июн 2026, 10:32 |
| Я тут случайно |
jonpim писал(а): Так может сам чип DRAM сдох ? Они тоже дохнут , но реже чем нанды . Возможно. Как тогда убедиться в этом? Ну или второй вариант. Как прошить нужный(полный) объем диска без DRAM на 2258XT?
jonpim
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 10 июн 2026, 10:48 |
Заменой . Вот ИИ тоже подтверждает Цитата: Ошибки Initial Param Fail или ISP Fail: Проблема может быть в изношенном чипе памяти, плохом контакте ножек или сгоревшей микросхеме DRAM-буфера. Проверьте плату на наличие окислов или трещин.
MoneyBot
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка |
shck
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 10 июн 2026, 10:54 |
| Я тут случайно |
jonpim писал(а): Ошибки Initial Param Fail или ISP Fail: Проблема может быть в изношенном чипе памяти, плохом контакте ножек или сгоревшей микросхеме DRAM-буфера. Проверьте плату на наличие окислов или трещин. А у меня таких ошибок то нет! Хорошо. Без замены чипа DRAM на текущем этапе я могу зашить конфиг на весь объем? Как? Чтобы понять стоит ли с DRAM заморачиваться.
MoneyBot
jonpim
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 10 июн 2026, 11:03 |
shck писал(а): таких ошибок то нет! ISP это загрузка прошивки ( Download Mp Package FW ) . shck писал(а): стоит ли с DRAM заморачиваться Зависит от мастерства хозяина
shck
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 10 июн 2026, 11:06 |
| Я тут случайно |
jonpim писал(а): ISP это загрузка прошивки ( Download Mp Package FW ) . Хорошо. Я понял. Спасибо! Выходит как : паять DRAM и верить в лучшее или сидеть на 640Гб -2 варианта, так?
shck
Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка  Добавлено: 10 июн 2026, 17:52 |
| Я тут случайно |
KUKUKUKUKUKU писал(а): Во первых очень много бедблоков, необходимо расширить допуски, во вторых это гиг ОЗУ, в третьих для прошивки нужно стереть весь родной системный блок и тогда пробовать Благодарю подсказки. Осталось разобраться что и как делать : 1. Расширить допуски. 2. Гиг ОЗУ (что?!- заменить чип?! Не понял). 3. Стереть весь родной системный блок. Это тоже еще ни разу не делал. Ну.. буду "курить". Если не сложно ткните на профильные ресурсы где об это четко почитать ( или все на юсбдев - достаточно?! ). Буду благодарен Скажем так - это всего лишь мой второй опыт по восстановлению прошивки. Поэтому и спрашиваю много. В любом случае спасибо что откликаетесь. Хоть вижу куда смотреть дальше
