Текущее время: 03 ноя 2026, 05:17
 Страница 1 из 1 [ Сообщений: 21 ]
 Заголовок сообщения: ADATA ASU800SS-1TT sata слетела прошивка
СообщениеДобавлено: 08 июн 2026, 10:47
Добрый день. Прошу помощи знатаков.
Испробовал все доступные варианты прошивок с раздела SMI MPTool SM2258 с префиксом L06B c юсбдев.ру.
Ничего не вышло.
Лог smi flash id v0.568a
OS: 10.0 build 19045
Drive: 4
Model: USB3.0 Super Speed
Fw : 0214
Controller : SM2258AA
Bank00: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank01: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank02: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank03: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank04: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank05: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank06: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank07: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank08: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank09: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank10: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank11: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank12: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank13: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank14: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank15: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank16: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank17: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank18: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank19: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank24: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank25: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank26: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank27: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Pure Spare Blocks : 0
Running Spare Blocks: 0
 Заголовок сообщения: Re: ADATA ASU800SS-1TT sata слетела прошивка
СообщениеДобавлено: 08 июн 2026, 11:59
А какой конкретно результат при попытке прошивки?
СообщениеДобавлено: 08 июн 2026, 12:37
Я так понял при более менее правильно подобранных настройках висит на "Download Mp Package FW"
Картинки
СообщениеДобавлено: 08 июн 2026, 14:53
Вероятно что прошивка не подходит. Память по автодетекту выставляется?
---------- Добавлено спустя 6 минут 58 секунд: ----------
Перебирайте пачку прошивок IM3D для 2258. начните с прошивок Qxxxx
СообщениеДобавлено: 08 июн 2026, 15:28
Нет, память сам всегда выбирал "intel 256gb..".
Те тоже пробовал, но не все. Сейчас начинаю..
СообщениеДобавлено: 08 июн 2026, 15:30
Вот 3 шт
Если не прошьет - тогда сначала rdt-selftest . Может нанда замучена :-):
СообщениеДобавлено: 08 июн 2026, 20:31
А шьёте через что ?
SATA ? USB ?
"Анархия -мать порядка " - вольная трактовка "Теории хаоса "
СообщениеДобавлено: 08 июн 2026, 21:07
пока не пойму что это и как делается -) Ваш вариант с прошивками не помог. Либо я что то не так делал.
BMA писал(а):
А шьёте через что ?
SATA ? USB ?
Через USB карман(универсальный) в котором был SSD .
СообщениеДобавлено: 08 июн 2026, 23:23
Лучше использовать карман на контроллере Jmicron, память по автодетекту определять, так нужные параметры мптул сам подгонит.
СообщениеДобавлено: 09 июн 2026, 09:25
Желательно карман на контроллере JMicron или Asmedia и с прошивкой NoUASP.
СообщениеДобавлено: 09 июн 2026, 22:41
Как раз таки карман на контроллере Jmicron. А точнее 1 карман, а второй адаптер sata-usb.
карман
https://disk.yandex.ru/i/mZtFihF5AQP_Xw
NoUASP пока не понимаю что такое. Прочту. Если есть конкретно куда ткнуть - ткните пожалуйста:)
Предложенные "ДО" варианты не сработали. Может конечно я что то сделал не так потому что это всегда было после 00:00. Но еще попробую, конечно.
---------- Добавлено спустя 4 часа 25 минут 28 секунд: ----------
В итоге завел на 2258XT S0909A0. Обьем 640Гб. Других вариантов пока не вижу..
---------- Добавлено спустя 33 минуты 43 секунды: ----------
Q0914B дала также 640ГБ но на sata2
СообщениеДобавлено: 10 июн 2026, 07:36
А если вручную выставить объем, в ошибку валится?
СообщениеДобавлено: 10 июн 2026, 10:13
Тогда размечается 200Гб с небольшим и все.
Я вот никак не пойму почему ни одна прошивка не подошла для 2258 с буфером. Вообще не хочет вставать. Никак.
SMI_в_ATA_режиме_пишет
Please select drive number:4
Drive: 4(USB)
Model: ASU800SS-1TT
Fw : S0909A0
Size : 610480 MB [640.1 GB]
From smart : [SMI2258XT] [S0909A0 00] [IM00]
Controller : SM2258 bufferless
FlashID: 0x89,0xa4,0x64,0x32,0xaa,0x1,0x0,0x0 - Intel 32L(L06B) MLC 256Gb/CE 256Gb/die
Channel: 4
CE : 6
TotDie : 24
Plane : 4
Die/Ce : 1
Ch map : 0x0F
CE map : 0x5F
Inter. : 6
First Fblock : 2
Total Fblock : 548
Total Hblock : 9539
Fblock Per Ce : 548
Fblock Per Die: 548
Original Spare Block Count : 40
Vendor Marked Bad Block : 0
Bad Block From Pretest : 27
---------- Добавлено спустя 11 минут 50 секунд: ----------
На прошивках L06B ошибка DRAM size постоянно.
Ставлю 128, 256, 512Мб Самсунг. Идут тесты. Ошибка размера памяти ОЗУ "DRAM size.."
Ставлю 1024мб Самсунг. Вечный загруз.. "Download Mp Package FW"
Для примера Nanya 1024Мб лог
STEP : Pretest Procedure (0x31)
ERROR : Find error from DRAM data. (0x04)
<<<<< Pretest ERROR Analysis >>>>>
(0x13) : Too Much Bad!
--- Total Plane Bad Block numbers for each channel and ce ---
CH 0 1 2 3
CE0 0017 0016 0016 0024
CE1 0020 0012 0019 0016
CE2 0026 0026 0042 0014
CE3 0038 0018 0020 0027
CE4 0032 0017 0017 0026
CE5 0000 0000 0000 0000
CE6 0021 0018 0017 0017
CE7 0000 0000 0000 0000
СообщениеДобавлено: 10 июн 2026, 10:29
Так может сам чип DRAM сдох ?
Они тоже дохнут , но реже чем нанды .
СообщениеДобавлено: 10 июн 2026, 10:32
Возможно. Как тогда убедиться в этом?
Ну или второй вариант. Как прошить нужный(полный) объем диска без DRAM на 2258XT?
СообщениеДобавлено: 10 июн 2026, 10:48
Заменой .
Вот ИИ тоже подтверждает
Цитата:
Ошибки Initial Param Fail или ISP Fail: Проблема может быть в изношенном чипе памяти, плохом контакте ножек или сгоревшей микросхеме DRAM-буфера. Проверьте плату на наличие окислов или трещин.
СообщениеДобавлено: 10 июн 2026, 10:54
А у меня таких ошибок то нет!
Хорошо. Без замены чипа DRAM на текущем этапе я могу зашить конфиг на весь объем? Как?
Чтобы понять стоит ли с DRAM заморачиваться.
СообщениеДобавлено: 10 июн 2026, 11:03
ISP это загрузка прошивки ( Download Mp Package FW ) .
Зависит от мастерства хозяина :-):
СообщениеДобавлено: 10 июн 2026, 11:06
Хорошо. Я понял. Спасибо!
Выходит как : паять DRAM и верить в лучшее или сидеть на 640Гб -2 варианта, так?
СообщениеДобавлено: 10 июн 2026, 15:04
Во первых очень много бедблоков, необходимо расширить допуски, во вторых это гиг ОЗУ, в третьих для прошивки нужно стереть весь родной системный блок и тогда пробовать
СообщениеДобавлено: 10 июн 2026, 17:52
Благодарю подсказки.
Осталось разобраться что и как делать :
1. Расширить допуски.
2. Гиг ОЗУ (что?!- заменить чип?! Не понял).
3. Стереть весь родной системный блок. Это тоже еще ни разу не делал.
Ну.. буду "курить".
Если не сложно ткните на профильные ресурсы где об это четко почитать ( или все на юсбдев - достаточно?! ). Буду благодарен
Скажем так - это всего лишь мой второй опыт по восстановлению прошивки. Поэтому и спрашиваю много. В любом случае спасибо что откликаетесь. Хоть вижу куда смотреть дальше
В этой теме нет новых непрочитанных сообщений. asu800ss-256gt
Барзанукаев Ислам
06 май 2017, 13:28
Барзанукаев Ислам Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Jovy RE-7550 слетела прошивка
Neadekvaten
12 апр 2018, 16:28
Neadekvaten Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. dgs-3650 слетела прошивка
в форуме D-Link
floyd_123
15 фев 2020, 12:31
floyd_123 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. слетела прошивка AK8287_AHD&16CH
в форуме Ремонт видеорегистраторов | Repair DVRs
pall-dnb
12 янв 2021, 18:44
sergedjan Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Canon Pixma MX495 Принтер .Слетела прошивка ,ошибка 6000 .
Джамбулец72
2786
03 дек 2020, 21:05
Джамбулец72 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 13
