Текущее время: 28 ноя 2026, 00:31
 Заголовок сообщения: Asus X550JX power on black screen
СообщениеДобавлено: 03 янв 2025, 21:27
Hello everyone,
I have an Asus X550JX laptop that automatically turns on as soon as it receives power. The Num Lock, Caps Lock, and Power LEDs light up, but there is no display on any port.
I followed the power sequence diagram from the circuit schematic, and everything seems to be in order. I connected a debug card to the LPC port via the debug connector, but it only displays a single "0," which theoretically indicates that there is no communication on the LPC port. Examining it with an oscilloscope also confirms that no data is visible on the port.
The PCH crystals appear to be functioning (25MHz crystal, 20MHz oscilloscope). The PCH reads the BIOS flash memory.
What else would you recommend checking?
 Заголовок сообщения: Re: Asus X550JX power on black screen
СообщениеДобавлено: 05 янв 2025, 13:05
What I also measured is that the PCH does not communicate with the RAM or the LVDS IC on the SMBus. Could the PCH be dead?
СообщениеДобавлено: 06 янв 2025, 04:11
Сделайте замеры сопротивлений на USB портах (D+/D-).
какое потребление тока на лабораторном блоке питания?
СообщениеДобавлено: 06 янв 2025, 08:11
I have already measured the USB D+/D- lines, and there is no short circuit. I don't remember the exact threshold voltage precisely, but it was around 4-500mV. When powered by a lab power supply, a minimal current flows immediately after connection, then after about 1 second, it rises to 1A and remains stable at that consumption.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. x550jx-xx106t (x550jx rev: 2.1) bios help
ahmeterengul
10 сен 2018, 23:33
ahmeterengul Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Insprion 7567 (bbv00/10 la-d993p rev 1.0) No screen, black screen.
в форуме Dell
anarasgarli
22 фев 2018, 13:23
anarasgarli Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus gl702vmk (Gl702vm) Black screen
kostukas1985
03 янв 2020, 15:31
kostukas1985 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS X751NV (BIOS+EC DUMP) BLACK SCREEN
в форуме Поиск BIOS
TPC
19 фев 2022, 14:03
sergej66 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 1660SUPER ASUS TUF, Black screen but after 2 seconds the image returns on the desktop.
azzed
06 фев 2023, 10:51
Adena Перейти к последнему сообщению
