Текущее время: 28 ноя 2026, 00:44
| Автор |
borisz94
Заголовок сообщения: Asus X550JX power on black screen  Добавлено: 03 янв 2025, 21:27 |
| Интересующийся |
Сообщения: 22 Откуда: Hungary
Hello everyone,
I have an Asus X550JX laptop that automatically turns on as soon as it receives power. The Num Lock, Caps Lock, and Power LEDs light up, but there is no display on any port.
I followed the power sequence diagram from the circuit schematic, and everything seems to be in order. I connected a debug card to the LPC port via the debug connector, but it only displays a single "0," which theoretically indicates that there is no communication on the LPC port. Examining it with an oscilloscope also confirms that no data is visible on the port.
The PCH crystals appear to be functioning (25MHz crystal, 20MHz oscilloscope). The PCH reads the BIOS flash memory.
What else would you recommend checking?
MoneyBot
Заголовок сообщения: Asus X550JX power on black screen |
